1.Z, I checked with the radius of gyration of typical FSAE Cars in pitch and roll (which is 600mm and 300mm respectively) .My values may be wrong(infact they are wrong) but its close to actual values.All these values are anyways ballpark values because I don't even know the exact CG height and weight distribution of my car . Infact I don't even know the exact unsprung or sprung weight of my car.
2.Z & Claude , Could you comment on my damper code selection? Its at the lower right corner of the damping rate spreadsheet.
3.Also one more thing I wanted to say that I plotted a graph of motion ratio variation v/s bump travel. Now its within 1.5% at the front and within 3% at the rear (for 1.6 inch of travel in compression and rebound). Its degressive obviously but as far as I think it wont make much of a difference because the above numbers would lead to a 3% and 6% increase in roll rates at the front and rear(due to (MotionRatio)^2)) respectively and that too when we assume that the travel is 1.6 inch in compression and 1.6 inch in rebound which is too much for my case(<.5 inch dynamic wheel travel). So any comments on the above?
