Hi
I have very troublesome one that is Ignition problem.
I removed the spark plugs so that Cranking freely. than Trigger is adjusted.
It sparks well.
Than I set the spark plug into head. But It doesnt saprk.
So I remove the spark plug where head.
Therefore It works.
At manual, PS-1000 can't controll ignition coil direlty.
So I wired Power Transistor each cylinder.
IB -> ECU (Falling eadge) E(ground) -> ground CO -> Ignition coil (-)
Than... It sparks with twin cylinder.. ............... - -
Do you think that I must buy Haltech Ignition module???
It is very hard to set Ignitor
