Results 1 to 2 of 2
Thread: SAE Italy: Wrong Point Calculation ?!
    Hello,
    maybe it's because I'm stupid, but:
    To make a quick check if my points calculation spreadsheet is right, I've entered some times from SAE Italy 2011 autocross, but I don't get the same results.
    http://www.ata.it/upload/alleg.../autocross-event.pdf
    Due the follow the SAE rules (http://www.ata.it/upload/allegati_su...rules-2011.pdf), the equation should be:
    =142.5*((tmax/tyour-1)/(tmax/tmin-1))+7.5
    tmax = 1.25 x tmin
    Right?
    The best time was 48,734 s, so tmax is 60,918 s.
    If a team finishs slower than tmax, the should get 7,5 points.
    So why is a team with a 61,266 time getting 47,980 Points?
    I've just seen in the result document that the are using 68,228 s as tmax.
    So the factor is 1.4.
    Does anybody know why the are doing this?
    Just wondering ...
