They are very popular with the top level national racers when they have a spare moment to do so.
They are also very popular with drivers trying to advance into sprint cars as they handle very similarly.
Specs:
Mass: Minimum kart and driver weight is 450lbs (204kg) total (with fuel).
Track width: adjustable from about 38-46" (965 - 1168mm), depends on kart manufacturer
Wheelbase: adjustable from 41-43" (1041 - 1092mm)
Rear Gear : 13-15 tooth drive gear, 23 - 75 tooth driven axle gear
Engine: Open class, 550cc 2 or 4 stroke engine (both have same displacement), typically make 85-100hp (63 - 75kW) at the crank. Peak rev is typically 8-12k rpm.
Tires: different for each corner and variable from slick or treaded and 11x5-6 to 12x9-6 (diameter x width - wheel diameter)
Brakes: One rear brake on the rear axle and one left front wheel. The right front does not use a brake.
Frame: standard oval racing offset chassis with a cage made from 3/4" x 0.083" tubing. The cage is sprung from the kart via 4 valve / die springs at each corner.
CG:I'd estimate the CG is 55% left side weight, and about 12-18" (457mm) high due to the wing height, driver height, and upright driver seating position.
Aero:
CLA and CD are hard to quantify but there is also attention to CLS that is needed.
Most people are familiar with coefficient of lift and coefficient of drag, but many are not familiar with coefficient of side force or literally Fy from aero forces which this generates a lot of.
Either way, it is a single element giant wing with asymmetrical end plates. Throw some numbers in simulation.
The wing is adjustable in angle of attack via a push-pull cable from the driver and is directly mounted to the cage. This in effect means that the chassis is unsprung mass, but the wing and roll cage is sprung mass.
Interestingly changing these springs change how the karts fundamentally handle.
Cost:
The top-of-the-line open kart chassis is available for about $4500 without motor. Race built motors tend to run $1-5000 depending on the quality and reputation.
Used, these karts can be found for $2-8000 with motor.
