Absolutely agree on "testing conditions".
Back in 2011 we did also some tests about weight sensitivity and CoG height, Inertias, etc.. So we used the 2011 car and put weight every corner that we could find in the car once a time and compared lap times. The driver just went faster and faster each lap. I think in the end he had like 40kg in the car and still ran the same laptimes.
But it was an amazing laptime drop after we removed all the weights and let him run as a reference in the last stint...
So if you test "wrong", you can prove that basically nothing is important
Btw on the topic:
We switched from 13 to 10 inch back in 2012 because of weight but mostly because of heat-up. We had a 180-ish kg non-aero car with 13" Hoosier and we simply were not able to heat them up significantly. With 10inch LC0 this was not an issue.
The 2012 car directly won the FSG AutoX (against GFR Combustion, probably first time an E-Car was faster than all combustion cars in AutoX).
Last year we switched back to 13inch because we started tyre development with Conti - they are not able to produce 10inch tires but the OD is roughly the same as for the 10inch Hoosiers.
As I am way too old, I cannot comment on how good they work. Zurich had the fastest FSG AutoX time again, so probably not too bad. Karlsruhe with Hoosier was not much slower (and won due to the cone) though...
