Hello guys,
I am from IITK Motorsports Formula Student team, India. I am doing the electronics for the car. We are running a KTM 500 EXC motor this year and we've imported it from UK.
We have been facing some strange issues with running the engine with the stock EFI system. If all the sensors are connected, the FI warning light is all right, but there is no pulse to the injector on cranking. There is spark though. On removing the coolant temp sensor, and then cranking, there is pulse to the injector, but it cuts out above 1500-1600 rpm. I've checked the coolant temp sensor resistance and its correct. The values for all other sensors have been checked by back probing, and all are giving in range values. After all these efforts, we are bound to conclude that there is some problem with the ECU.
With just one month remaining for the competition and the engine not running, we are out of options. A new stock ECU would cost us around $350- $400 after shipping and customs, and around 10 -12 days time. While discussing this with the team, we came to a point that if we buy an ECU from Performance Electronics, and we get the stock maps from KTM (or somewhere else), we would consider that over the stock ECU, because KTM and our engine dealer have provided really poor technical support. With the PE ECU, we would at least have something to diagnose, along with good community support. Plus the ECU was already in agenda for next year's car, so no waste of money there.
Just wanted to ask you guys, if some of you have the stock maps for the KTM 500 EXC or XCW (or any map that would get the engine running at the competition). I am really not asking for anything you have tuned or created, just the stock ones, if you are willing to share. I'll be really grateful!
Thanks in advance,
-Harshit
