Z, Menisk, others: Would you mind continuing your argument elsewhere, preferrably offline? It has kind of steered away from the original topic and onto general FSAE philosophy and rules committee bashing, as usual...
Christian: You're right about the uprights! Welded sheet metal has the advantage that you can make them by yourself and a 10% increase of stiffness in the upright probably gives you more performance gain than a 10% decrease in weight...
Concerning the brake cylinders I posted earlier, yes I meant to say 8mm rod ends... In case anyone is interested, they're made by a VERY small company in eastern France called "Beringer", their lead times are sometimes a few months and sourcing them can be quite tricky.
