Results 1 to 6 of 6
Thread: Bottle with CO2
    Lightbulb Bottle with CO2
    Dear competitors,
    I am AGH Racing member from Krakow. Do anybody know, if shifting bottle located near our engine could provide risk and we will be not allowed to compete, pictures below:
    Kind Regards,
    Patryk Bindacz
    Member
    Jun 2003
    Houston
    92
    If that bottle was filled with CO2, then I imagine your main concern/question would be rule T10.1(d) protection from rotating equipment failure (right next to diff and/or chain). However, since the bottle is apparently filled with radioactive "pure energy," I'm sure it's fine.
    Any time you are in doubt, it is best to formally ask the rules committee.
    University of Texas 2002 & 2003
    University of Houston 2007
    Dear Rex,
    Thank you for your response, We checked in the FSAE Rules rule 10.1 tonight and we guess everything will be ok at the competition.
    Kind Regards,
    Patryk Bindacz
    I foresee bigger problems in your future...
    I would be more concerned with the lack of any scattershield on the chain than the placement of the bottle, the bottle will get you through scrutineering the lack of scattershield not. We ran with the bottle quite close to the engine. The disadvantage is that the pressure fluctuates as the engine heats up which could result in less (or not at all) predictable pressure from the regulators. This is mostly the case if the lines running from the pressure regulator are near the engine.
    Tristan
    Delft '09 Team member, '10 - Chief Electronics
    'now' (Hardware) Security Engineer
    The location of the lines is not the problem. Overheating of the regulator itself can be (we used a wet towel and duct tape to keep it cool during endurance at FSG 2010 ), but as long as it is out in open air I wouldn't be too worried about it. If you do run into shifting problems, you know where to look first though.
    Make sure the bottle and regulator cannot be damaged in case of chain failure (proper scattershield should be enough I think, but I'm not a scrutineer) and also make sure that it has good (stiff) mounting to frame or engine.
    DUT Racing Team (Delft) 2008-2010
