Just did the calcs ... around 3.1s (obviously close to accel times of the electric cars now). The big point here is that for these 4wd electric cars the tyres only need to provide a mu of 1.5 in all conditions, which is pretty reasonable. The power is controlled through the motor controller, which is the ultimate traction control. No gear changes to sap power. No need to play around with weight balance or COG height.
The power limit comes into effect after the first 1.8s (42% of the run).
This was done for a 200kg car. Change it to a 300kg car the time drops a whole 0.1s to 3.2 seconds (getting closer to where we are now) and the power limit comes into effect after 1.2s (62.5% of the run). The power limit for electric cars is effectively limiting how long you can have the extreme acceleration.
I have heard of 1.7g accel from the electric AWD drive cars, and obviously believable. In this case the run would be improved (with a 300kg car) to 3.1s, with the power limit coming into effect after 0.9s. (71% of the run)
So the AWD electric cars can do the ultimate times that Z suggests, but with a lot less effort, and on the power limit nearly the whole time. All the calcs here (Z's as well) are not including the effect of drag, which obviously slows things down, and will almost completely account between the difference of 3.1s to what the electric cars are currently doing. Also allow for a margin teams will be running to ensure they do not cross the 80kW limit.
Please note that I didn't crack open my proper sim code, and just did this roughly on excel. But I think the results are fairly clear, and close to expectations.
Of concern is that if the AWD electric cars are dropped to only 50kW of power they will do the run in about 3.45s, allow a couple of tenths for drag and we are still at 3.65s and they only need to worry about grip for less than 0.6s. Even with a big drop in EV power we will not be seeing the petrol cars faster than the EV's without doing a lot of work.
