The following taken from a 2013 version of the Rules, but I remember similar at least as far back as ~2000.
D7.2 Autocross Course Specifications & Speeds
D7.2.1 The following standard specifications will suggest the maximum speeds that will be encountered on the course. Average speeds should be 40 km/hr (25 mph) to 48 km/hr (30 mph).
* Straights: No longer than 60 m (200 feet) with hairpins at both ends (or) no longer than 45 m (150 feet) with wide turns on the ends.
* Constant Turns: 23 m (75 feet) to 45 m (148 feet) diameter.
* Hairpin Turns: Minimum of 9 m (29.5 feet) outside diameter (of the turn).
* Slaloms: Cones in a straight line with 7.62 m (25 feet) to 12.19 m (40 feet) spacing.
* Miscellaneous: Chicanes, multiple turns, decreasing radius turns, etc. The minimum track width will be 3.5 m (11.5 feet).
D8.6.2 The standard specifications for the FSAE Endurance Course are:
* Straights: No longer than 77.0 m (252.6 feet) with hairpins at both ends (or) no longer than 61.0 m (200.1 feet) with wide turns on the ends. There will be passing zones at several locations.
* Constant Turns: 30.0 m (98.4 feet) to 54.0 m (177.2 feet) diameter.
* Hairpin Turns: Minimum of 9.0 m (29.5 feet) outside diameter (of the turn).
* Slaloms: Cones in a straight line with 9.0 m (29.5 feet) to 15.0 m (49.2 feet) spacing.
* Miscellaneous: Chicanes, multiple turns, decreasing radius turns, etc. The standard minimum track width is 4.5 m (14.76 feet).
... etc....
(My emboldening.)
Part of what originally attracted me to FSAE is this focus on "agility" of the cars (in the Rules at least!). A bit like going to the circus to watch the acrobats, rather than watching a running race like a marathon (yaaaawwnn, ... except for when they start collapsing at the end...) .
~~~~~~~~~~o0o~~~~~~~~~~
(My emphasis again.)Originally posted by Claude:
I wish there could be 3 or even [more] hairpins really 180 degrees in a row. It is low speed for sure but I guarantee you that it is spectacular. You will see the cones flying. You will see the good drivers and the good cars and the bad car driver wishing for a handbrake!
Claude,
YAHOOOO!!!!! I knew there would be something WE AGREE ON.
I am 1,000% with you on this one! And also the "more bumps in the higher speed corners...".
Raitinger,
The Hough loader (rhymes with "rough and tough") that I used to own was a bit bigger than the CAT you linked to, and I recall it having a tighter turning circle (the two inner wheels almost touched).
I have a "World Cars Catalogue" from the 1960s that has a page of specs on each of the models built that year (I picked it up for ~$1 at a school fete). I flicked through it last night and there are many cars there with turning circles less than 10 metres "between WALLS" (so this includes the nose overhang).
My old Pug 404, with a wheelbase of 2.65 m (104", so medium/full-size passenger car), from that era is listed with turning circle of ~9.6 m (between walls). It had very conventional front-strut-suspension and R&P steering. Interestingly, many similar sized cars have much larger turning circles, some up around 12 m. The main difference between these cars is the quality of their detail design. The Peugeots where very conventional designs, but very well executed.
FSAE is supposed to an "educational" exercise. Yet I see many VERY BADLY designed steering systems on these cars. A little probing reveals that "the steering was done by some guy N? years ago..., and so far it works sorta OK, so we keep using it". In other words, none of these students have learnt, or will learn (?), how to design a good steering system. And when they go into the passenger car world, the attitude is "Well, the customer should practice their three-point turns...". Not a good attitude, IMO.
And, BTW, the biggest advantage of an exceptionally tight turning circle? Watching your passenger's face as you rather suddenly do a U-turn in a narrow alley!
Anyway, here (hopefully) is some ascii-art of a hairpin that would benefit the well-designed cars (eg. simple, low-powered, non-aero cars, with attention-to-detail-steering), and would penalise the cars with bad steering geometry, or perhaps with a long-overhang, wide front-wing.
.. = used as spacers,
o = cones,
8 = haybales or water-barriers down middle.
xxx = path of car with "good" tight steering.
......o...o..o..o...o......
..o.......................o..
..o.........x..x.........o..
..o.....x....8....x.....o..
......ox.....8.....xo......
......o.x....8....x.o......
.......|<--9m-->|.......
xxx = path of car with "bad" steering.
....|<---15+m--->|....
..o.......x..x..x.......o..
..o..x................x..o..
..ox....................xo..
..o..x.......8.......x..o..
......o..x...8...x..o......
......o...x..8..x...o......
Note extra distance covered here. Maybe +1 sec, at least?. Or they can knock over cones...
For safety the Enduro should have a slow entry to a short hairpin-entry-straight, and the safety barrier down the middle. The AutoX can have the hairpin(s) at the end of a long straight, and no centre barrier, because only one car on track at a time.
