Originally Posted by
uG
"Per T8.4.1, "Exposed high-speed final drivetrain equipment such as ... electric motors, must be fitted with scatter shields in case of failure." (You are of course still required to use the steel material as the chain scatter shield.) For the shield around the motor housing, we will allow you to use 'mesh' or expanded sheet metal (aluminum or steel), as long as it meets or exceeds the perforation size requirement at T8.4.6 "must prevent the passage of a 12 mm (1/2 inch) diameter object through the guard." I realize the other language at section T8.4.6 regards 'parts that spin while the car is stationary,' but after discussing we request that you use the perforation details stated there, as a minimum specification."
