how to design a bell crank for push rod suspension
hi sir i am nikhil mehrotra age 20 . i am currently working with my team to design an electric car for formula14.
As i am new to the project, i am currently facing problems in designing my bell crank.
Both the front and the rear geometries are completed and now we are working on designing our bell crank.
we are using pushrod suspension for both front and rear.
plzz help me so that i get some idea on how to design my bellcrank.
Another way to raise the CG
Quote:
Originally Posted by
Did you calculate how much the CG would raise with rising rates?
Not the answer to your question, but a related story:
I measured CG rise on a C3 Corvette cornering on a circle. This version (1968 - 1982) had high roll centers F and R (rear fixed-length half-shafts were also the "upper control arms" for the independent rear suspension). Roll was around an axis that connected (approximately) the tire contact patches on the outside pair of wheels. There was droop on the inside wheels, but negligible bump travel on the outside. CG height increase was approx 1/2 the amount of droop (rebound) on the inside suspensions.
