POWERTHIRST, it's the downstream restrictor for GRATUITOUS AMOUNTS OF ENERGY!
The restrictor functions on a difference in pressure differential. Usually it is referenced to atmospheric pressure, which then defines your maximum flow rate compared to the vacuum drawn by your engine. If you move that downstream of the turbo, you then end up in a situation where the restrictor no longer is limited by the vacuum, but by how pressurized you can get the air to force it through that tiny restriction. Not regarding efficiency and eventually melting turbos, power becomes unlimited. Essentially, your mass flow rate is no longer limited, which makes it an easy decision to run a turbo in that configuration over NA.
Turbo-609.9cc here I come. ;)
To circle back to the placement of the throttle, a leaky throttle in an naturally aspirated application allows more air to flow by circumventing the throttle while in a boosted application it would leak down presssure, decreasing mass flow rate, decreasing power. It actually seems pretty practical.
PS...
Please, don't go and prove what the downstream restrictor would practically restrict the engines to. I've had enough lower member swinging contests this week. Also, couldn't pass up a Powerthirst reference.
