What Has Been Established So Far.
1. Anyone who believes the world is a globe circling the sun is a lunatic, a risk to society, and should be burnt at the stake! As everyone knows, the world has hills and dales, which makes it truly 3-D. But other than that it is a flat 2-D plane. Err..., supported at its corners by four huge elephants... that stand on a giant tortoise... and below that it is turtles all the way down! http://fsae.com/groupee_common/emoticons/icon_smile.gif
2. If the Bible of RCVD says "In true three-dimensional space, instant centers are replaced by instant axes..." (p612), then it MUST be true! And, of course, the 250+ year old concept of a "screw axis" is the work of the devil!!! If a computer Suspension Program claims on the packaging that it is "fully 3-D" (like the one Z trialled a few years ago), then that MUST also be true. Even if the results it gives for "anti-pitch/roll" are calculated according to RCVD type "instant axis theory", so often have errors of 10++%. http://fsae.com/groupee_common/emoticons/icon_frown.gif
3. A US manufacturer of pick-up trucks makes the goddamn best handl'n vee-hikels on the whole gosh-darn planet! Apparently, they do this by spending a lot of time in casinos rolling dice... Hey, that's gotta be more fun than doing geometry, especially during Happy Hour! http://fsae.com/groupee_common/emoticons/icon_smile.gif Oh, and Porkers handle like... well..., porkers... http://fsae.com/groupee_common/emoticons/icon_frown.gif
4. Z will never, ever, ever be welcome in a Product Development Design Review Committee Meeting. Err... ever! ("Yahoo!", thinks Z, "They're sooo boring..."). And the game of Tennis, like so many other fields of endeavour, really does benefit from KISS. Winning Tennis players do, indeed, just keep hitting the ball over the net. By analogy, winning FSAE cars just keep going fast around corners. Which they can do without suspension... http://fsae.com/groupee_common/emoticons/icon_smile.gif
5. Finally, for those slackers who are too lazy to do their homework (try Find!), Z is a nobody from nowhere, who has done nothing, no-wise, ever... Err..., other than mindlessly ramble on about some long lost bunkum called "Classical Mechanics". And, err..., endlessly ask for some rational discussion on suspension design. But, geez... "reason" ain't gonna educate engineers, is it? http://fsae.com/groupee_common/emoti...n_confused.gif
~~~o0o~~~
Moving on..., (or back?) to FSAE suspension design.
So far nobody has argued against the notion that "suspensionless cars" can go fast around smooth circuits. Likewise, no compelling arguments that the most complicated suspension types are necessary for a FSAE car to be fast.
Is this agreed? Any "Nays"???
So, on the assumption that FSAE suspensions could be much simpler, I will, in later posts, go through the pros and cons of the top five on this list.
But would anyone else like to give their thoughts first?Quote:
... the major suspension types are,
1. Beam-axles (eg. on all vehicles ever, can be live or De-Dion at rear),
2. Sliding-pillar (eg. Morgan and Lancia, and most motorbikes and aeroplanes at front),
3. Lateral swing-axles (eg. Tatra (still on their trucks), can be high or low-pivot),
4. Leading and trailing-arms (eg. Citroen 2CV front and rear, and most motorbikes at rear),
5. Semi-leading/trailing-arms (eg. F100 at front, and many mid to late 1900s cars at rear),
6. Strut-wishbone (eg. McPherson at front, strut at rear),
7. Double-wishbone (eg. originally mostly at front to allow shorter wheelbase with front engine),
8. 5-link (eg. recent fashion, mainly for NVH reasons).
Of these, any of the first five are more than adequate for a winning FSAE car.
For example, Claude says,
And Tony says,Quote:
While I am less convinced about the efficiency of semi-trailing arms and even less about live axles (actually I call them dead axles, I always have been convinced that you can make a good car with a McPherson.... but if you if you miss the window of good mix between of tire exploitation and kinematics design it will be more difficult to make a change. Providing some suspension pick up points adjustability, with a 5 links or a double wishbone you can get and/or adapt the heave and roll camber variations, roll centers, pitch centers position and movement to what the tires (and good drivers) "need" much better than with a McPherson. And if for whatever reason you are forced to switch to another brand of tire, your design could not be adaptable...
As a student I will most probably go for a double wishbone or a 5 links.
Now I don't like any of the above options, and have rational critcisms of them which I will give later (and, of course, which is why I'm not welcome in any meetings! http://fsae.com/groupee_common/emoticons/icon_smile.gif).Quote:
Double wishbones are an obvious natural choice at the front, but at the back, I am not so sure.
There can be a lot of problems with the potential for bump and compliance steer at the back with a double wishbone design, which seems to be a regularly occurring design problem area on many FSAE cars.
Good solid toe control at the back would have to be be pretty high on my wish list.
A single stiff rear trailing arm, with transverse upper and lower camber control links would give excellent toe and bump steer control while being simple.
But in the meantime, Claude and Tony, would you like to "defend your decisions" any further, in a Design Tent sort of way?
It might be helpful to the "education of young engineers".
