Quote:
Originally posted by Z:
Yes, some decisions are plain STUPID. A good example at this recent comp was the large number of cars with front pushrods leading to rockers and spring-dampers mounted ON TOP of the noses. Yep, rockers and spring-dampers mounted to give the highest possible CG, the maximum yaw inertia, and all that extra, though unnecessary, chassis tubing and bracketry up there.
Thank you for bringing such a brilliant example. You may be personally convinced that this is the case, but there are some very good reasons for having the dampers on top of the nose. The forces you introduce into the chassis can be massively reduced and you can get to extremely better spring rates, especially when using 10'' tires.
