Jan - Thanks again! You don't have to sugar coat the build quality, we know it's awful and it's one of our big things to improve, the reason it's so bad was because time simply ran out :( For the pedal box reservoirs I was thinking if a banjo was just used to turn the outlet 90 degrees then the reservoirs could be off to the side shrouded by a small plate/floor access 'hump'. I did look into vertical mounted master cylinders too but I think this method has the ability to push the bulkhead even closer to the pedal face.
z - Ahh ok I understand that now :) I did a bit of thinking on the beams (drew a few sketches, going to build a physical model later) and something that seemed to be the case was this:
Beam = best camber control roll/bump, worst in single wheel bump, most un-sprung mass
LLink = worse version of beam (poor camber control in bump) less un-sprung mass, slightly better camber control in one wheel bump (unaffected wheel stays flat)
Swing arms = similar to LLink really, higher RC if parallel to ground.
Double-wish (with average FVSAL lengths) = pretty much the 'jack of all trades master of none' largest number of hardpoints, some (possibly lots) camber deficiency in bump and roll, un-sprung similar to that of LLink but likely the best at dealing with one wheel bump situations.
I guess the interesting point is that, we run on tracks with no kerbs that are completely flat so why do we care about one wheel bump situations at all? and if they do happen they're likely to be infrequent.
So I'm actually leaning towards beam axles... but I do feel like I've been slightly pushed that way, certainly makes rear hardpoints easier.
The idea of a custom casting is something we have thought about and it's possible it will happen in the future depending on if one of our team members gets his placement at the casting company.
I get the 60/40 argument, it's just if we can actually achieve it, we're still trying to shuffle everything as far back as we can get them to go whilst being reasonable.
915mm is the leg length. See the MC's under floor doesn't make the frame higher in my mind, if the MC's are sat just above the lower edge of the frame rail then there only needs to be a slight height increase in the floor above them. If this point is under the bend in the drivers legs then why does it matter that the floor is higher there?
Fun bit?!!!!! It would be fun if I had years to think about it yeah, it's the time issue that makes it substantially less fun!
Matt - Thanks I'll have a look for that and pass it on to the driver environment guy too. Well to be honest 'big picture VD' is effectively my project title but it goes under the guise of 'suspension' here, that's partly due to a lack of understand about the project but I wouldn't like to discuss that any further for obvious reasons.
Mitchell - That makes sense now, I just couldn't see the vertical slot, if we were going down the beam axle route we'd probably have to go with two shocks since I doubt one of our small shocks could take the load on its own. I see what you're saying about the MR too, seems simple enough :) The pedal box will likely be sliding on the frame rails with a simple pin dropping through the pedal box and frame (with a split pin to stop the pin falling out), easy to adjust and simple to make. I too will be surprised but I think it is possible providing everyone really pushes it.
Jay - Interesting thoughts, I'll pass them on to the engine/dry sump guy.
MCoach - Nice idea with the mock up, we actually had a full set of scales but they've just been sent off for repair as the load cell gave up in one of them. I see the benefit with the high roll centers (more kinematic weight transfer = faster than elastic transfer) but how high is really too high? I have no experience of what I'm aiming for here, 50% elastic, 50% kinematic transfer? 90% elastic, 10% kinematic? I have very little reference points to go off, likewise with how much steering lock do I want? All I know is that last year 28 degrees at the outside wheel wasn't enough but how much does that need to increase by to be useful? or was it because of the awful ackerman that made it so clumsy around corners? All questions, all tricky to answer when starting from zero.
Just a quick thought (I have a lecture in a minute) but if I was to go to a front beam axle, where would I mount the steering rack? on the beam seems easy but then it will be rotating and moving WITH the beam, wont this lead to strange steering characteristics?
Thanks all of you for your input, it's really helping us all out here! :)
