Scott,
If less than one-tenth of my posts here are on this general subject (in truth, probably many more), then I still have well into triple figures of posts ranting about it! :)Quote:
How undesirable do you find ARB's?
...Can you expand on your position on the subject?
So, very briefly, of the many ways to interconnect wheels with springs, the "ARB" (or "lateral-U-bar", which interconnects "end-pairs" of wheels) is one of the worst. Yes, it does stiffen the Roll-mode, which can be beneficial for some types of car (sometimes, but not always), but it also EQUALLY stiffens the Twist-(aka-Warp)-mode, which is generally VERY BAD for all cars.
A much bettter choice of wheel-pair interconnection is the "longitudinal-Z-bar", which interconnects "side-pairs" of wheels. (Note: "Z" is the shape of the bar in plan-view, and not any relation to me. :) "U-bars" resist opposite movements at their ends (eg. up+down), and "Z-bars" resist same movements (eg. up+up, or down+down).)
"Side-pair-Z-bars" are good because they stiffen Heave and Roll, while NOT affecting Pitch and Twist. They also make it easy to adjust Elastic-Roll-Moment-Distribution (~ LLTD) to allow easy adjustment of US/OS. And packaging complexity is similar to ARBs. In principle, a complete (and very good!) suspension for a car can be made from two side-pair-Z-bars, and a third end-pair(=lateral)-Z-bar, typically at the heavier end of the car. No more is needed!
The only real downside of side-pair-Z-bars is that almost no one in the entire auto-world knows about them! Oh, ... and if, say, someone in F1 stumbles onto them, and they start winning races because of them, then the organisers start jumping up and down, shouting "It's FRIC-ing cheating!!!", and they immediately ban them as being against the spirit of motorsport. ("FRIC" was a hydraulic Front-Rear-Inter-Connect ... Z-bar.)
Aaaarghhhh, ... progress!!!
Getting back to FSAE, it is desirable for the car to have the lowest possible CG-Height, to allow the narrowest possible Track-Width for better slalom speed. Bumps are almost non-existent on the tracks, but some damped suspension movement is beneficial to suppress "bouncing on the tyres', which can start by "stick-slip" of the tyres during hard cornering.
So, what sort of "springing" to use?
Since the major masses are distributed mainly along the centreline of the car (eg. IA and pedals at front-centre, driver's bum in middle-centre, engine at rear-centre), it follows that to have a low CG, this car-centreline should run at a minimum ride-height, and it should NOT be allowed to move up-down much. So it should be STIFFLY SPRUNG.
So end-pair(=lateral)-Z-bars are well suited. These, of course, are also known as "third-springs" (actually seventh and eighth), and work well at controlling changing aero loads. More below in reply to Claude, but rising-rate is GOOD here!
That only leaves the Roll-mode to control, since Twist-mode can be left soft. So side-pair-Z-bars can be added. Or, for easier packaging, simple, softish, corner-springs can be used (ie. they only connect to one wheel, so simplest type of spring).
Note that with appropriate suspension kinematics there is NO disadvantage (on the smooth FSAE tracks) of having a soft Roll-mode. Here "good kinematics" are those that give ~100% "camber recovery". So, beam-axles, or independent suspensions with Front-View-Virtual-Swing-Arm = ~half-Track-Width. With these the car can have low CG and also considerable Roll-Angles, but nothing touches the ground (since main masses along car-centreline and any undertray can be "unsprung"), and tyres maintain high grip because always close to zero camber.
Note that for very bumpy roads the preferred kinematic behaviour is ZERO camber recovery, mainly because of the gyroscopic forces involved. But that ain't FSAE!
More coming next post.
I haven't had time to read your links, but may add more later after checking them.
BTW, you can "Search" this Forum for my ranting on "Z-bars", starting back in 2005 (there was a sketch in one of the posts back then).
