http://i1296.photobucket.com/albums/...ps36ee34ae.png
Advantages - CofG is low down, could only be lower with a pull rod under the floor (The reason I've not done this is because I'm pretty sure the valving in the damper will be backwards (as in compression is a pull, rebound is a push) and I don't know if we will be able to get the shocks re-valved (yet!)). Other advantages are that the motion ratio can be altered and digressive, linear or rising rate springing can be achieved with the rocker design.
Disadvantages - As you can see, it makes life difficult with the footwell template, again more complexity, more nodes to reinforce, larger forces through the 'pull rod' due to the angle, etc. Probably more!
