Ashir,
You have enlightened me to the sheer "genius" of modern engineering.
I used to think that the modern approach to engineering, as seen in a lot of FSAE, simply involves COPYING whatever the current fashion happens to be, and then justifying your "engineering decisions" by offering up some lame, half-baked, CALCULATIONS as support.
But, no, I was completely wrong. Absolutely NO calculations are required! Not even any sort of rational, or well-reasoned, qualitative analysis. Instead, you only have to regurgitate a few HALF-TRUTHS, and then back them up with a mountain of IRRELEVANCIES, and BLATANT BULLDUST. Sheer genius!!!
For example...
Quote:
Originally Posted by
Ashir
I went in more depth of search results and visited this topic
http://www.fsae.com/forums/archive/i...hp/t-408.html?
conclusion seems good for me.
... my objective is to design the suspension based on the damper we already have. This will save us lot of money (more than what it will be saved on using direct damper mounting by removing bell crank and pushrod costs).
So now I have to make my suspension stiff without changing damper, I will use bell crank to chance motion ratio.
It seems that your decision (in that post) is to use "bell cranks" (= pushrod-and-rockers) because your previous car already has them, so it is easier for you to keep doing the same. Is this your thinking?
(Edit: I just read your above post more closely, and it now seems that you may move to direct-acting SDs, but only if they have MR close to 1?)
So far, in your decision making, you seem to be happy with the following arguments. (These are taken from the above-linked thread, and are my main reason for ranting here... :)).
Quote:
For the shock to work well, and also to allow lighter springs (both in rate as well as in mass), the MR needs to be somewhere near 1:1. Modern formula cars strive for 1:1 for the front (if not higher), and even higher for the rear. This allows the springs to be of lighter rate and mass, ...
Pure BULLDUST!!! (And, frankly, pure STUPIDITY!) For a given wheel-rate and travel, more spring travel (ie. higher MR = damper/wheel motion) requires a lower spring-rate, but also a proportionally LONGER SPRING!
Thinking about it "big-picture-wise", the integral of wheel-force x wheel-travel = strain-energy to be stored in the spring. So, for springs of equal strain-energy/mass capability (ie. for the same quality of spring steel), a given wheel-force x wheel-travel requires the same mass of steel, regardless of MR!
(Of course, fibreglass, or rubber-band, or gas, (or other...), springs ARE lighter for the same total strain energy storage, again regardless of MR...)
Quote:
[the magical MR=1] ... also pumps more fluid for every increment of wheel movement.
The more fluid that the shock can pump - especially with the high wheel rates we have on modern cars - the easier it is for the shock to be fine tuned for good spring and tire contact patch control.
The "high wheel rates" come when incompetent suspension engineers eventually discover that "any suspension will work, if you don't let it...". However, these incompetents believe that they got the suspension working by "fine tuning" it.
As for "pumping more fluid", just how much fluid needs to be pumped (ie. how much energy needs to be dissipated) to control these teeny-weeny racecars, as they race around their billiard-table smooth tracks? (Please do the calculations, and see that it = SFA.)
Also, if you double the MR, then you double the "static friction" forces felt at the wheelprint due to stiction in the damper seals, etc. Generally, this is a bad thing.
Quote:
... the higher the MR the less force that is put into the frame where the Coil-over dampener attaches.
This is one of those half-truths that obscures several more important facts. Namely, for given Fz wheel forces the stresses felt by the main portion of the chassis are, quite obviously, the same regardless of suspension details (as explained by The-Man). A pushrod at the same angle as a DASD, has, quite obviously, the same forces acting on it. The addition of a rocker with high MR simply transfers this same force to two, hopefully smaller, forces at two separate chassis nodes (ie. the rocker node, and the SD node).
"So, hey, why not 10 x pushrods, rockers, and dampers per corner!? Yeah, then the force into each of the, err... 10, no that's 20 chassis nodes, is only, err... 1/20 of what it was before... Genius!!!" :)
Quote:
If you practice with 39 C ambient temperature, and 53 C track temperature (like we do here at our country), radiator flow is really critical, and a shock in the way is a big problem.
Groooaaannnn... See below...
The above-linked thread had some discussion (by Big Bird ++) along the lines of,
"If you are in close competition with Stuttgart at the front of the field, then tiny details such as the exact MR of your rockers might make the difference between 1st and 2nd place.".
Sounds plausible... Except that Monash won the most recent FSAE event, Oz-2013, with direct-acting SDs. And they won by the proverbial country mile! And they have an aero car, so it seems that DASDs don't mess up aero flows too much. And Monash have a side-mounted radiator, and they test and race in Oz, "the sunburnt country", with the FSAE comp held in summer. So DASDs don't seem to kill radiator flows too much either...
But Monash are not a Northern Hemisphere team like Stuttgart. Does that make a difference? Should it? They were briefly at the top of the FSAE ladder (IIRC, sometime last year?). And they have been hovering around there for quite some time...
Anyway, on that linked thread from 2010 there was a post from Fil (who seems to have been on the Monash team?) who said that he did a study of DASDs and concluded that they "actually made sense". I recall Monash at Oz-2013 pointing to a bucket full of pushrods and rockers (= dead weight and $$$s) as justification for their move to direct-acting SDs.
So, does anyone know how long Monash have been running DASDs, and what their competition record with them is?
(Important point: Your decisions should NOT be swayed by what some other team does, except, perhaps, as confirmation of your calculations!)
Bottom line;
Know thyself!
Are you doing what you are doing because it really makes sense, or simply because it is easier to follow the flock?
