The above photo is of RMIT R05 at the Oz 2005 comp, which went on to win FSAE Detroit in 2006. I have posted it as it is a good example of swing axle geometry - without the simplicity.
Reasoning? The short VSA's were an attempt to achieve full camber compensation in roll, noting that our simulations were showing that lateral accelerations were around 8 to 15 times more important than longitudinal accelerations. We were happy to compromise our contact patches in pitch a little to keep the patch flat on the road in cornering.
We had noted that with the track map we had to work with, 10 of the 14 cornering manouevres were entered with no pitch attitude - i.e. no braking. Therefore we wanted camber compensation right from when the car would first start to roll.
The fault? The car would lift the inside rear right from corner entry, and would then transfer all the torque the inside rear when under power - no drive. The team then over a few years progressively dropped roll centres and tightened up the diff (torsen then moving onto clutch packs) to get the power down on exit.
Think of where the c of g of the unsprung mass is - it is at axle height. Now think of where the instantaneous centre is for the VSA - below axle height. Now imagine the unsprung mass inertial force under cornering, and what sort of a moment it will create around the IC of the VSA, and how little moment of inertia the unsprung mass has with such a short VSA...
Instant lifting of the inside rear right from turn in. Terrible when you are trying to get a torsen to work on corner exit. So you can either try to fix the geometry to suit the final drive you have - OR thinking a little laterally, could you find a final drive to suit that kind of geometry?
Hmmm...
