Originally Posted by
POWER - As noted at length elsewhere, the maximum achievable IC engine power through the 20mm restrictor is about 120 hp. Also covered elsewhere is the historical fact that air-cooled, turboed, 450cc singles were putting out 120+hp over 40 years ago. So a "sporty four" has NO POWER ADVANTAGE over a single!
Note that I am not advising that you try to get 120 hp out of a 450cc motocross engine that was only designed for 60 hp max (the crank won't take it!). Instead, you would have to build your own, but that is not hard (ie. just copy above example), and FSAE is supposed to be an "engineering" competition. Also, the current fours are nowhere near that power yet, so no rush in developing said 120 hp single...
