You should explain WHY you think it's such a gamble to try one of many Z's suggestions. Earlier I explained that sure, there is very little out there on FSAE cars that isn't double wishbone suspension, but there have been cars that use 'other' suspensions that are very competitive. Single cylinders, v-twins, and four cylinders have all managed to win at different points and times, why not different types of suspension as well?Quote:
Hello "Z",
You miss a point there... engineering is not solely based on the idea to have the best concept ever... Engineering is to MAKE THINGS WORK ! And one of the aspect of making something work is risk management. Your ideas are perhaps great but they are a HUGE gamble. With the numbers of years we put in every FSAE years it's a huge gamble.
You also miss another point : gain.
What is the gain Z? We want laptimes comparaison, we want compliances study and weight study, we want drag and downforce figures, we want inertia and CG comparaison...
Give us figures! Science is based on facts. Be an engineer. The day you prove your point, well all FSAE will be rocking those beam axled side-engined mutli-steered cars on whatever tire you used with the frame type you used. And there is no problem with that.
You might have the best ever concept but a concept is just a concept. History is written on what is done not what is thought.
As far as facts and figures go, there's a lot you can figure out without building anything. In face, a LOT of money is spent on engineers who say they can figure stuff out before they build it, bc it costs a lot less money to do it that way.
Car companies release concepts that usually are better than the final product. What's wrong with Z's concepts? After all, that may be his strategy: hoping some of us will pull the wool from our eyes and try something new and potentially more competitive.
_____________________________
4WS should be totally allowed in the current rules:
Steering
T6.5.1
The steering wheel must be mechanically connected to the wheels, i.e. “steer-by-wire” is prohibited or
electrically actuated steering, is prohibited.
T6.5.2
The steering system must have positive steering stops that prevent the steering linkages from locking
up (the inversion of a four-bar linkage at one of the pivots). The stops may be placed on the uprights
or on the rack and must prevent the tires from contacting suspension, body, or frame members during
the track events.
T6.5.3
Allowable steering system free play is limited to seven degrees (7°) total measured at the steering
wheel.
T6.5.4
The steering wheel must be attached to the column with a quick disconnect. The driver must be able
to operate the quick disconnect while in the normal driving position with gloves on.
T6.5.5
The steering wheel must have a continuous perimeter that is near circular or near oval, i.e. the outer
perimeter profile can have some straight sections, but no concave sections. “H”, “Figure 8”, or cutout
wheels are not allowed.
T6.5.6
In any angular position, the top of the steering wheel must be no higher than the top-most surface of
the Front Hoop. See Figure 3.
T6.5.7
Steering systems using cables for actuation are not prohibited by T6.5.1 but additional documentation
must be submitted. The team must submit a failure modes and effects analysis report with design
details of the proposed system as part of the structural equivalency spreadsheet (SES) or structural
requirements certification form (SRCF). The report must outline the analysis that was done to show
the steering system will function properly, potential failure modes and the effects of each failure mode
and finally failure mitigation strategies used by the team. The organizing committee will review the
submission and advise the team if the design is approved. If not approved, a non-cable based steering system must be used.
I wonder how much extra development time and driver training having 4WS would take. I think it's most definitely a try before you buy idea on an old car. Lots of testing, lots of decisions to make.
Ian, if the steering is all mechanically attached, but you have electronics that say 'switch gears' in the rear steering to change the steer direction (turn left wheels left to turn left wheels right) then I believe you would be in the clear. You aren't electronically controlling the steering, just what will happen when you steer.
