Z,Quote:
Originally posted by MCoach:
Z is just advocating very simple systems for a very simple competition. The cars should posses these systems and no others (to keep it simple):
<UL TYPE=SQUARE><LI>A single cylinder engine
<LI>A simple frame (preferably painted brown)
<LI>A single speed transmission
<LI>Longitudinally connected springs (help with bump capability)
<LI>Diagonally connected springs (to stiffen in pitch and roll)
<LI>Don't forget interconnectedly sprung left to right
<LI>NO FANCY SUSPENSION, beam axles front and rear
<LI>DIRECT actuating dampers that are cheap as dirt and don't work because you don't use them. The courses are smooth enough that you don't need to worry about wheel movement, but they are just bumpy enough that you need to spring all of the wheels together.
<LI>Pull/push rods are unnecessary
<LI>Suspension should be robust enough to enter the Baja SAE competition with
<LI>An aero package capable of 3G on an autocross couse but still is rules compliant with less drag than a non aero car. (but aero also isn't considered a big enough deal to try to move dampers and springs out of the air stream).[/list]Remember guys, keep it simple. http://fsae.com/groupee_common/emoticons/icon_razz.gif
Assuming you agree with (at least some of) the above, where do you stand on:
<UL TYPE=SQUARE><LI>active yaw control?
<LI>four wheel steer?[/list]To me, many of the manoeuvres required for FSAE are not best achieved by conventional front wheel steer vehicle dynamics:
<UL TYPE=SQUARE><LI>why yaw the car when driving a slalom?
<LI>why create yaw moments via axle translation forces?
<LI>why pivot the car around a turn centre within the wheelbase
<LI>(etc.)[/list]With beam axles, many common parts could be used to easily achieve 4 wheel steer.
Additional actively controlled brake systems are not banned, as long as there's a simple passive braking system in place as well.
I can envisage a 'sidewinder' car with a very short chassis structure and the engine beside the driver. A beam axle front and rear, mounting off the front and back bulkheads. A 2nd brake caliper for each wheel linked to a control ECU. Mechanical linkage rear steering (no steer-by-wire) using cams or similar to program the rear steer characteristics for each event (accel, skidpan, autocross). If necessary, a selector lever, a bit like a gear shifter / ARB adjuster / weight jacker, to select different rear steer characteristics around the autocross lap.
Regards, Ian
