Quote:
Originally posted by Z:
Markus,
"So should the goal be that the car withstands everything? While being light and not made to withstand everything?
... you can't have both."
Well, actually you can. The Model T Ford (~700kg), VW Beetle (~720kg), and Citroen 2 CV (~530KG) were all designed to be as simple as possible, while still being "mid-size four-passenger cars". These cars are all very light (weights dependent on spec), but they also have the rugged off-road capabilities that very few 2+ ton SUVs have today.
KISS really works.
None of the mentioned cars are "very light" especially compared to their spec. I'd say medium weight, or you could give them light if you where looking through heavily shaded KISS-glasses while being almost pope-drunk.
Quote:
"PS. You didn't comment anything on saving the dampers in the driveshaft problem..."
I have no idea what happened to your dampers/driveshafts. Honest ... I was not there ... I didn't do it ... Smile
But I am sure that spending excessive money on dampers is a poor use of resources. And spending even more time and money building deliberately fragile wishbones/pushrods&rockers, just to "save the dampers", is also a waste of resources.
Focus on the "big picture"...
With only a very limited mechanical understanding you should be able to visualize a couple of possible cases of what could have happened. There is not many ways how a driveshaft can jeopardize a DA-damper or push-/pullrod.
