Using Optimum K for analyzing bumpsteer
Hi all,
I'm working on steering for Columbia University's team, and I'm wondering if there's a feature on Optimum K that can help with analyzing bump steer. Specifically, analyzing bump steer with different sized steering racks. I'm very new to Optimum K, so I apologize if this is a stupid question.
Thanks!
Bump steer with compliances
Additional perspectives
Bump steer (or Roll steer) could be VERY different with and without compliance.
Here is a little test to do
A No compliance; no spring no damper no ARB
1. Cut a few pieces of wood of 20, 40, 60, 80, and 100 mm.
2. Put them under your car ideally not too far away from a vertical plane to the ground passing though the wheel center of one axle (front or rear)
3. For each step measure the toe angle at each wheel
4. Create a spreadsheet of toe or toe variation Vs ride height or ride height variation (which is the same as wheel movement Vs the chassis)
5. Use this test opportunity to also measure the camber variation and the damper eye-to-eye length. That will give you your motion ratio.
B. With compliance
Drill 2 holes on each side of the car, insert an plastic anchor and a hook in each hole, then put the straps (the ones you use to secure the car on the trailer will do the job) over the car from one hook to another
Use the straps ratchet to pull the car down.
Make the same measurements made in test A but this time make sure you also carefully measure the wheel center height variations (taht will gibve you the tire deflection that you will have to subtract from the ride height variations). Or use solid, dummy wheels
I guarantee you will find VERY different camber or toe or motion ratio Vs ride height curves
If you do thees measurements make sure you take picture and create a good document to show the design judges.
If you have scale under each tire that would be better. Warning: read the scale user manual (ahaha again) to amke sure you do not overload the scales. If necessary use 2 scales side by side on which you will have put a piece of wood between the scales and the tire to distribute the tire load on the 2 scales.
But you will also have to show them how you use these curves in your car design and tuning.
Also remember that in this test these are only vertical compliance, no major lateral or longitudinal or torsional efforts are exerted on the tires
