    FSAE.com Forums    FSAE.com Forums  Hop To Forum Categories  FSAE.com Gallery    Have a look at the LR08 Frame
Hi Folks,
if you want to, you can take a look at photos which we are taking while we are welding our frame. The archive is updated every 2-3 days. I hope you enjoy the show.
http://www.flickr.com/gp/23543277@N07/207n9q
Regards,
Tobias
Head of Electronics '06 '07 '08
Lions Racing Team Braunschweig
- Three nations have not officially adopted the International Metric System of Units as their primary or sole system of measurement: Liberia, Myanmar and the United States.
- 1 Inch was defined to be the thumb width of Heinrich, I., King of England.
- Later 1 Inch was redefined to be the length of 3 barleycorns by Eduard, II., King of England.
- 0°F were defined by Fahrenheit in the harsh winter of 1708/1709 as he thought that it is impossible to become colder than this
- 100°F were defined by Fahrenheit to be the normal temperature of the human body. Obviously he had fever, when measuring his own body temperature to define his scale.
Posts: 79 | Location: Braunschweig, Germany | Registered: October 31, 2007Reply With QuoteEdit or Delete MessageReport This Post
"A" for manufacturing process. I love that jig table!
Terps Racing
Posts: 50 | Registered: June 20, 2006Reply With QuoteEdit or Delete MessageReport This Post
I think we have the same fixturing table.
It is so nice fabricating with real fixtures.
Wild Hare Racing:
The Heat and Power Lab may be a hole, but it's a hole with history (and asbestos!)
Posts: 24 | Location: South Dakota State University | Registered: October 16, 2006Reply With QuoteEdit or Delete MessageReport This Post
Thanks,
the whole team is looking forward to the engagement between engine and frame next week. We will then continue to post pitures in the album.
Regards,
Tobi
I noticed you have used Catia to design your chassis, how did you go about profiling the ends of the tubes so they fit together ?
Posts: 43 | Location: England | Registered: May 20, 2006Reply With QuoteEdit or Delete MessageReport This Post
flo
We have a Masterpart in which all important geometries and interfaces are defined. This Masterpart contains a wireframe of the frame. The frame it self consists out of different Parts, a Masterpart for the frame and a part for every single tube. The Masterpart for the frame includes the wireframe as a linked result and it defines all bisecting planes of the angle between two tubes. In the tubeparts we design the tubes. A tubepart includes as well its referenz line and the bisecting planes ,which are required to cut the tube in shape, as linked results.
Tubes with different outer diameter do not fit together using bisecting planes. In this case we link two tubeparts together and use geometric operations to fit the tubes together.
We had a little trouble to get the links to work and not to generate loops, but in its third evolution our CAD structure works fine.
Lions Racing
www.lionsracing.de
Posts: 8 | Location: Germany | Registered: February 11, 2004Reply With QuoteEdit or Delete MessageReport This Post
Thanks for that. I have been using GSD and the Join/trim function for profiling the ends of the tubes, but it won't let me close the chassis. For example if I want to join the seatbelt bar to the roll hoop, you can only profile one end, as the seatbelt bar becomes part of the rollhoop on the first operation.
Posts: 88 | Registered: June 10, 2005Reply With QuoteEdit or Delete MessageReport This Post
http://www.flickr.com/photos/lionsracing/2262914188/in/set-72157603863531783/
mullet?
This is me. Looks funny on this picture, but I think the effect is caused by the jacket ;o)
Head of Vehicle Dynamics
Lions Racing Team, TU Braunschweig
Posts: 48 | Location: Braunschweig, Germany | Registered: September 16, 2006Reply With QuoteEdit or Delete MessageReport This Post
flo
Hi Chris,
i knew this problem from our LR06. We designed the frame in one Part as well. At that time we solved the problem by duplicating every tube several times and using only these doubles in the Boolean operations. Today i would suggest to use paste special with result as link instead of paste. In 2006 it took us several hours to change a wall thnickness.
I hope it helps.
Lions Racing
www.lionsracing.de
We've used Solidworks this year for the chassis, which has a nice tube joining function in the weldments section. Given that Dassault Systems bought Solidworks, its odd that they've not included it, maybe its included in the higher level versions.
Thanks for the help. When is the first run of the car scheduled? Were hoping to get our car running in the next few weeks.
Hey Chris,
we plan to have it rolling on the beginning of April. Depends mainly on the last stage of the frame building as we are waiting for our butt straps at the moment.
Where is your team from? (England, yes, but where in England?)
Regards,
Tobi
I'm from Hertfordshire, UH Racing.
www.uhracing.co.uk
1st 2006 Class 1-200 ,1st 2007 Class 3 Design and Overall, Class 1 team 2007/2008
Hey folks,
we have new pictures online. The engine was placed inside the frame and we have also made some pictures of our wishbone jig.
Regards,
Tobi
Hey guys,
I just want to mention that we migrated our photo gallery from Flickr to our homepage. From now on, you will find our pictures at http://www.lionsracing.de/component/option,com_ponygall...ry/catid,83/lang,de/
I am still transferring pictures and we will continue to update the gallery every 2 or 3 days, so check back regularly if you are interested in our progress.
Regards,
Tobi
are your chassis tubes milled?
Finished @ UofT Racing
2003-2007
www.fsae.utoronto.ca
Posts: 197 | Registered: July 09, 2003Reply With QuoteEdit or Delete MessageReport This Post
Nope,
they are laser cutted.
Regards,
Tobi
even nicer....wow....
must be nice to just have to weld it together...we are still stuck with manual prepping....Big Grin
2003-2007
Again some new pictures since we began to assemble the LR08: www.lionsracing.de/photos
@RacingManiac: Yes, it helps a lot and as you can see on the pictures, they usually fit well. We are very happy to have a sponsor doing this for us.
Regards,
Tobi
Laser cutting is not all it's cracked up to be. There is a good .010" per foot tolerance on the cuts, with even more deviation on thick bars. So really you can't use laser cutting for the hardpoints, diff mounts, etc. But for the side impact structure, bulkhead, etc. it's a godsend.
--Walter Röhrl
Posts: 291 | Location: Sandy Hook, CT | Registered: July 13, 2006Reply With QuoteEdit or Delete MessageReport This Post
