    FSAE.com Forums    FSAE.com Forums  Hop To Forum Categories  Off Topic    2008 chassis complete!
Picture of ttk3
After a grueling 26 hour marathon of grinding and welding galvanized conduit (cough), we have a rolling chassis! The next 8 months will be dedicated to a phenomenal push-bar design.
http://picasaweb.google.com/TKusnierz3/FirstDrive07/photo#5107697007984718066
http://picasaweb.google.com/TKusnierz3/FirstDrive07/photo#5107697050934391138
It was an interesting first drive, as the four wheel steering took some getting used to... http://www.youtube.com/watch?v=pHV-vAbGAC4
Posts: 34 | Location: Rochester, NY | Registered: May 16, 2006Reply With QuoteEdit or Delete MessageReport This Post
Picture of Christopher Catto
nice little chassis.
the galvanised tubing, well, at least all areas apart from the weld wont rust. then put some good rust proof agent on the welds and you have a much more durable steel chassis than most. so you can race forever, till the wheels fall off literally.
good luck for the rest of the car. enjoy the fun. Smile
...we got emergency on planet earth
Posts: 116 | Location: Cambridge, UK | Registered: August 11, 2007Reply With QuoteEdit or Delete MessageReport This Post
Looking at those pictures, that main roll hoop looks welded. I don't think that's allowed:
3.3.4.2 Main Hoop
The Main Hoop must be constructed of a single piece of uncut, continuous, closed section steel tubing per Section 3.3.3.
Just thought you should know, anyway maybe I'm wrong...
Regards, Ian
Posts: 345 | Registered: July 15, 2003Reply With QuoteEdit or Delete MessageReport This Post
Those Oklahoma guys better get their frame done ASAP. The pushbar award is on the line!
Matt Brown
Alum
U. of Oklahoma
http://sae.ou.edu
Posts: 158 | Location: Valencia, CA | Registered: April 19, 2005Reply With QuoteEdit or Delete MessageReport This Post
cut off the top section add a radius section, bondo, sand and paint. Big Grin
Posts: 28 | Registered: December 11, 2006Reply With QuoteEdit or Delete MessageReport This Post
Picture of Biggy72
We should be starting to build our rebar chassis here pretty soon so we're not too far behind you guys.
Posts: 229 | Location: Olympia, WA | Registered: February 10, 2006Reply With QuoteEdit or Delete MessageReport This Post
Picture of drivetrainUW-Platt
We used plastic conduit for our last mockup. Might have won us design if the damn duct tape would have held up better to people getting in and out of it...grrrr.....
Mike Duwe
UWP Alumni
Picture of Kyle Walther
SHHH!!! you're giving away all the secrets!!
University of Oklahoma alum
Sooner Racing team...sae.ou.edu
" I see no point in being the richest man in the cemetery."
"Bail!! Bail!!"
Posts: 175 | Location: Cranfield, Eng, UK | Registered: June 09, 2004Reply With QuoteEdit or Delete MessageReport This Post
Picture of ttk3
That's what I wanted to do! I'm tired of being involved with the projects that take years off my life (welding galvanized conduit, locking myself in a room to grind chromoly for months on end, etc). Bring on the plastic and hot glue!
Picture of Anday
plastic tube can get pretty unhealthy too.
when PVC gets hot it releases chlorine gas. that's some pretty nasty stuff too.
but welding is a lot easier with hot glue, it's a lot like MIG.
Posts: 25 | Location: Dekalb | Registered: October 06, 2006Reply With QuoteEdit or Delete MessageReport This Post
TG
Picture of TG
There are a couple problem areas you will need to address. The main roll hoop tube can't be welded and has minimum bend radii. The upper side impact bar has maximum and minimum height restrictions. You guys should take a good look at the rule book because it will save you a lot of headaches in the long run.
Posts: 219 | Location: Tempe, Arizona | Registered: February 08, 2005Reply With QuoteEdit or Delete MessageReport This Post
Picture of ttk3
Thanks for the help TG! I think we'll probably just bring several sets of different sized casters with us so that we don't get hung up on any height restrictions in tech.
man how I miss all the fun of FSAE Frown
Micah McMahan
ODU FSAE "Dodging bullets and building cars"
04 member, 05 controls/member, 06 control/ergo/brakes , 07 brakes and the small engine Wink
Posts: 314 | Registered: April 25, 2004Reply With QuoteEdit or Delete MessageReport This Post
