    FSAE.com Forums    FSAE.com Forums  Hop To Forum Categories  Off Topic    Most horsepower per dollar!!!
Picture of drivetrainUW-Platt
http://www.impulsengine.com/how/index.shtml
Have at it.... small diameter headers and hot air induction systems....you be the judge
Mike Duwe
UWP Alumni
Personally I'm waiting out for hover cars =]
Posts: 78 | Location: UWA Motorsport, Perth | Registered: July 19, 2004Reply With QuoteEdit or Delete MessageReport This Post
Picture of absolutepressure
Well, you could make all of those modifications (which were very vauge), or you could slap on a turbocharger and the the same output. How the hell would you heat the incomming air? I guess you could put a heating element from a blow dryer in there, but it seems like a lot of work. As intake speed would increase, intake air temp would decrease because of less contact to the heating element, and then you would be at less than optimal temperature. You would also, then have to vary the injected water temperature. Other losses would be seen in the pumping force required to force the exaust gases out.
And, why would the intake open before tdc, because then it would just get pushed back out when it got to tdc. You'd think they'd want to open it after tdc to get an even greater vacuum pressure.
UW-P Vector Representative
"500 kilowatts of whoop-de-friggen-do electricity!"- http://www.impulsengine.com/performance/horsepower.shtml
"The pleasure of driving shouldn't be something that's reserved for people with very deep pockets."-Conor (I modified it a little bit)
Posts: 212 | Location: Platteville, Wisconsin | Registered: October 16, 2005Reply With QuoteEdit or Delete MessageReport This Post
but denny, its 1/3 the cost of a turbo/super and the same power!!!!
Mike Duwe
UWP Alumni
Picture of CrazyDave
heating the air would be easy,, the engine is always rejecting heat to the coolant so there would be a air to water, and then a water to coolant exhanger to heat the air..
although im very confused about the reasons listed to increase intake charge temperature.
but, the reason why you would want to do that
Posts: 15 | Location: Southfield, MI | Registered: June 14, 2005Reply With QuoteEdit or Delete MessageReport This Post
Picture of Jersey Tom
'Negative pressure supercharging' sounds an awful lot like just plain ol ramcharging/pulse tuning, but done really well to really kick up the volumetric efficiency of the thing.
Colorado FSAE Alum | 05, 06, 07 (C-Cpt)
Posts: 877 | Location: Boulder, CO | Registered: March 31, 2005Reply With QuoteEdit or Delete MessageReport This Post
Wow are they legitimately trying to sell this stuff? When I first saw it I thought it was a joke sight like this one KaleCo
Josh Gillett
Oregon State FSAE '04-'06
Posts: 343 | Location: Everett, Washington | Registered: August 25, 2003Reply With QuoteEdit or Delete MessageReport This Post
Dude, that site is hilarious! The O-pipe, provides 100% backpressure on ALL ENGINES! lol!
You bring up a good point, though. Do you see how they claim "violent acceleration" and "extremely violent acceleration?" Number one, who the fuck says that? And number two, extremely violent acceleration from a towing vehicle? So....like the acceleration of a top fuel dragster? That's extremely violent. Hey, buy this kit and you'll do 0-Fucktard in 3 seconds!!! Roll Eyes
Sorry for the profanity.
Edit: I don't think I got across what I was trying to say. I'll combine my two posts into a more poinient, less jockular statement. I think that thier product would work very well in a controlled environment, and in theory (except for the valve timing issue I addressed earlier). However, I believe that there are too many uncontrollable variables in the environment for this to be a reliable (or reliably provide a lot of power) system. For example; on Monday, it was 76 degrees. On Wednesday, it was 28 degrees. You would have needed to fush out the system and put antifreeze in there. But, then the temperature warmed up again, so the system would be at less than optimum. Even just differences between night and day would have a large affect in some areas.
This message has been edited. Last edited by: absolutepressure,
Picture of Ben Beacock
lol... I love the fact that instead of dyno numbers, they say 'it beat a subaru WRX'
Ben Beacock
Alumni
'03,'04,'05 Gryphon Racing - University of Guelph
Posts: 350 | Location: Guelph, Ontario, Canada | Registered: November 15, 2002Reply With QuoteEdit or Delete MessageReport This Post
I'm more inclined to beleive beating a Subaru than whatever dyno numbers they would put up.
Posts: 317 | Location: OK | Registered: September 24, 2006Reply With QuoteEdit or Delete MessageReport This Post
I love the page on negative pressure is as powerful as postive pressure. They start with a +15psi baseline and call that atmospheric pressure. Then they say -8 psi in the same paragraph reference from 15+ as a change of -23psi...last time I knew you can't have negative absolute pressure, so no negative pressure is not as powerful, especially negative pressure you cannot acheive.
'engine and turbo guy'
Cornell 02-03
Posts: 438 | Registered: August 02, 2004Reply With QuoteEdit or Delete MessageReport This Post
AEM sticker + Tein sticker + DC Sports sticker + tickets to Formula D event = -23psi absolute manifold pressure.
not to rip on drifters... but you know the crowd.
- B
Posts: 188 | Location: Maryland | Registered: October 07, 2003Reply With QuoteEdit or Delete MessageReport This Post
this is some funny crap....just made my day
wonder if they sell a sticker pack for the stage 8 kit and an increased 50 hp
Micah McMahan
ODU FSAE "Dodging bullets and building cars"
04 member, 05 controls/member, 06 control/ergo/brakes , 07 brakes and the small engine Wink
Posts: 313 | Registered: April 25, 2004Reply With QuoteEdit or Delete MessageReport This Post
Maybe while they've got the '07 motor cracked open I'll put a few stickers on the piston tops.
I'll make sure to get them from a thermal coating company.
Hey, it made my saturn dyno over 125 horses guys. C'mon, that's at LEAST worth something, an extra 1 hp. Smile
Campus policies left students shooting back with camera phones. Life's worth more than pictures.
www.ConcealedCampus.com
Posts: 123 | Location: Cincinnati | Registered: October 08, 2006Reply With QuoteEdit or Delete MessageReport This Post
ad
Cross drilled brake lines :P
Andrew
Posts: 138 | Registered: February 04, 2006Reply With QuoteEdit or Delete MessageReport This Post
Ok, so assuming you have an engine generating 40 percent more power (use a 200 kW baseline and 100 percent efficiencies) and 280 kW of heat to expel, lets see what that means for the cooling system (in a very general sense)... 280kW=mdot * cp * delta T... use 5gpm to determine your mdot, dumdedum, you get a delta T of about 210 degrees Celsius... I sure as hell wouldn't want that kind of temperature drop across my engine! Maybe 200 but come on 210 thats rediculous! Oh wait, I forgot some heat is used to heat the incoming air... so prob 20kW used for that, there may be hope! Only 260kW to cool now.. damn I was hopeful, still 195 degree drop, hmmm... I think we be cracking some blocks soon.
2003-2008 UF FSAE
Posts: 115 | Registered: June 09, 2005Reply With QuoteEdit or Delete MessageReport This Post
Picture of golfer17
hahaha, that kaleco site was awesome!
btw, i was wondering if there was any merit to making headers and an intake system and adjusting valve timing and a few other little things like they recommend on a normal n/a car(i wouldnt want to switch to a cold running motor though).
Bryan
SRT Powertrain
Posts: 20 | Location: Moore, OK | Registered: May 12, 2006Reply With QuoteEdit or Delete MessageReport This Post
I'm eyeballin those adjustable powerbands....my truck needs some more low end.
I just put some long tube Pacesetter headers on my truck, gas milage and horsepower went up...maybe I should put a ball valve in each primary to limit there flow and get some negative supercharging, heck maybe even a few blow off valves on the headers too?
Mike Duwe
UWP Alumni
