    FSAE.com Forums    FSAE.com Forums  Hop To Forum Categories  Off Topic    Short gear ratio n eliminating gears
Hello everyone. Can anyone explain to me what short gear ratio is? And I would like to know if there is a way to eliminate the first gear in our car. Currently the gear is 1-N-2-3-4-5. So I would like to eliminate the 1st gear so that it’ll be N-1-2-3-4 @ N-2-3-4-5. We’re using Honda CBR 600 F4i.
Posts: 1 | Registered: February 13, 2008Reply With QuoteEdit or Delete MessageReport This Post
Picture of The AFX Master
well if you plan to do so (our team did it years ago) you'll have a insanely big rear sprocket that is almost a 5th wheel.
you'll need almost 30% more theet on that sprocket if you want to mantain the same driveline ratio
I don't have the details of how to modify the gearbox to do so, but.. the big sprocket is already an issue.
This message has been edited. Last edited by: The AFX Master,
Drivetrain Leader 07-08
Team FSAE USB
Posts: 77 | Location: Somewherebourg | Registered: February 21, 2007Reply With QuoteEdit or Delete MessageReport This Post
We run a twelve tooth front and a 55 toth rear on a stock f4i. first gear is pretty much useless. its kind of just there if you really bog out in a corner and need to get your revs back up.
Mike D
UTSA 04-
Posts: 91 | Location: San Antonio | Registered: May 06, 2006Reply With QuoteEdit or Delete MessageReport This Post
