    FSAE.com Forums    FSAE.com Forums  Hop To Forum Categories  For Sale    Red Line Oils
Hello All,
I have the following Red Line oils for sale to benefit a charity set up to support a good friend of mine who was paralyzed in a motorcycle accident last August. All the money from this goes into this fund. See www.brotherbentlage.com for info about the fund.
It is a mix of Qts, Gallons, and 5 Gal pails. A few bottles have some cosmetic damage to them but all seals are intact. The prices listed are each and -40% from Red Line MSRP
48 x Alcohol Fuel Lubricant,4 cycle, 12oz, (Treats 55 gal)-$4.11
24 x Assembly Lube, 4oz-$3.90
24 x ATF, Racing, Qt-$5.49
6 x Diesel Fuel Additive, 85 Plus, 12oz-$3.57
24 x Diesel Fuel Biostat, 12oz-$4.79
5 x Gear Oil, Heavy Shock Proof, 1Gal-$20.40
1 x Gear Oil, Heavy Shock Proof, 5Gal-$111.15
21 x Gear Oil, Heavy Shock Proof, Qt-$5.85
4 x Gear Oil, Light Wt Shock Proof, 1Gal-$20.40
44 x Gear Oil, Light wt. 75W80, Qt-$4.79
8 x Grease, CV-2 High Performance Extreme Pressure, 14oz Tub-$5.85
6 x Grease, CV-2 High Performance Extreme Pressure, 14oz Can-$5.85
26 x Fuel System Cleaner, SI-2, 6oz $2.10
10 x Manual Transmission Fluid, MT-90, Qt-$4.79
18 x Motor oil, High Performance 10W30, Qt-$5.37
6 x Motor oil, High Performance 5W30, Qt-$5.37
26 x Power Steering Fluid, Qt-$5.37
2 x Race Oil, 20Wt, 1Gal-$21.48
46 x Race Oil, 20Wt, Qt-$5.37
34 x Race Oil, 30Wt, Qt-$5.37
16 x Race Oil, 40Wt, Qt-$5.37
2 x Race Oil, 50Wt, 1Gal-$21.48
1 x Race Oil, 50Wt, 5Gal-$102.03
37 x Race Oil, 50Wt, Qt-$5.37
5 x WaterWetter, 12oz-$5.37
4 x Winterized RL-2, 1Gal-$26.25
Thanks!
Posts: 4 | Location: Indianapolis | Registered: April 26, 2006Reply With QuoteEdit or Delete MessageReport This Post
This is an updated list to the one above. If it is not on this list then I am out.
Thanks!
Greg
23 x Assembly Lube, 4oz-$3.90
7 x Grease, CV-2 High Performance Extreme Pressure, 14oz Tub-$5.85
5 x Grease, CV-2 High Performance Extreme Pressure, 14oz Can-$5.85
23 x Fuel System Cleaner, SI-2, 6oz $2.10
18 x Race Oil, 30Wt, Qt-$5.37
4 x WaterWetter, 12oz-$5.37
Hello!
This is updated as of 4/27 at 10:30pm
17 x Assembly Lube, 4oz-$3.90
4 x Gear Oil, Heavy Shock Proof, 1Gal-$20.40
12 x Fuel System Cleaner, SI-2, 6oz $2.10
Thanks!
Greg
