    FSAE.com Forums    FSAE.com Forums  Hop To Forum Categories  For Sale    Aprilia SXV 550 engines Now Available
5-star Rating (3 Votes) Rate It!  Login/Join
Picture of Mechanicaldan
Here is the information to get you, quite possibly, the best engine for a FSAE car. The Aprilia RXV & SXV 450 & 550 engines. Do not contact me, see below for contact details.
Why is it possibly the best engine for FSAE?
Light weight, 72 lbs dry for the crate engine with sensors and throttle bodies (as you see it in the pictures below)
Unrestricted, 66+ HP
Electric start
Dry sump oil system
Very compact
Dealership details:
$3500/motor + shipping anywhere in the world.
engine comes with all sensors, fuel injectors, throttle bodies, and fuel rail.
20% discount on all parts which means that
~$200 for wiring harness
~$800 for ECU (The stock ECU is adjustable with TuneBoy software, or use a Power Commanders.)
If you would like to use one of these engines in you FSAE car, contact Art at Euro Cycles
Euro Cycles
6914 Johnston St
Lafayette, LA 70503
(337) 984-0477
The dealer cost on the motors is around $2500 for anyone trying to get one at another Aprilia dealership.
It’s not cheap, but you get what you pay for. 450s and 550s are available immediately, but in very limited quantities.
Some more info:
Owner / Service / Workshop manuals
Dyno curve of an unrestricted, stock SXV 550.
Here's a stock curve compared to an engine that has had some head work, aftermarket pipes, and free flowing air filter.
Picture of the engine on page 2 of brochure. It's so tiny!
http://www.apriliausa.com/upload/modelli/offroad/brochure_00111.pdf
Engine
77° V twin four stroke. Liquid cooled. Single overhead cam with rocker operated exhaust valves, chain timing drive, 4 valve heads, titanium valves.
Bore x stroke
450 - 76 x 49.5 mm
550 - 80 x 55 mm
Total displacement
449 cc
549 cc
Compression ratio
450 - 12.5:1
550 - 12:1
Starting
Electric starting.
Alternator
340 W.
Lubrication
Dry sump. External oil tank required. Separate gearbox lubrication.
Gearbox
SXV
1st 13/30
2nd 15/27
3rd 16/23
4th 20/23
5th 21/21
RXV
1st 12/31
2nd 13/25
3rd 15/23
4th 19/24
5th 21/22
Clutch
Multiple discs in oil bath, cable operated. (Slipper clutch may come available.)
Primary drive
Spur gears. Transmission ratio: 22/56.
Final drive
15 tooth front sprocket is smallest available from dealership. Sprocket Specialists does not have front sprockets available as of 10-27-06.
Front sprockets:
http://www.af1racing.com/store/Scripts/prodView.asp?idproduct=3115
or
http://www.apriliasupermoto.com/index.php?f=data_spares_$_accessories&a=1
MORE PICTURES ADDED BELOW - 1-5-06
This message has been edited. Last edited by: Mechanicaldan,
Dan De Clute-Melancon
Iowa State FSAE alumni
Project Manager 03-04
Engine Team Leader 02-03
Posts: 196 | Location: Louisiana | Registered: January 29, 2003Reply With QuoteEdit or Delete MessageReport This Post
Edited.
Picture of Kirk Feldkamp
Are these bikes going to be California street legal? If they are, that's badass.
Are both the 450 engine and the 550 engine the same price? $3700 is a boatload of cash, but I guess what can you expect from Aprilia? Roll Eyes What all is included in that price? Throttle bodies? Exhaust? ECU? Hoses?
-Kirk
Posts: 393 | Location: Newport Beach, CA | Registered: February 06, 2004Reply With QuoteEdit or Delete MessageReport This Post
Picture of Dan Deussen @ Weber Motor
Another great benefit is that this engine is originally equipped with a Walbro ECU (Model ECUC) which is freely programmable. It is the same ECU I use at work for the Weber MPE750. If there is interest from teams to use this engine, I would strongly suggest to also use the original ECU designed for this engine. It does not have any internal data logging capabilities like a MOTEC, but there is an agreement with AIM Dataloggers to have an external logger to get all the ECU channels through the serial connection into the logger. Please all teams that are seriously interested in using this engine with the OEM ECU, contact me an I will talk with the guys from Walbro, if you can get the software to recalibrate the maps.
Daniel Deussen
www.weber-motor.de
Saginaw Valley State University Alum
Cardinal Formula Racing '99 - '05
FSAE: 6th in '02 and 8th in '05
FSG: Scrutineer, Design Judge and Race Coordinator in '06, '07 and '08
Posts: 206 | Location: Markdorf, Germany | Registered: November 14, 2002Reply With QuoteEdit or Delete MessageReport This Post
Edited.
Sounds fantastic to me!
I just wish we were in that price range.
Someday.....
Posts: 18 | Registered: March 24, 2006Reply With QuoteEdit or Delete MessageReport This Post
Just taken receipt of a complete Aprilia RXV 550 Enduro motorbike for Liverpool University, it is quite honestly an absolute beast of a bike and sounds AMAZING.
Biggest problem i'm having here in the UK is being able to find the software to access the ECU and start getting to grips with it! For the time being the bike is complete and being driven to run the engine in, a week today see's me starting to take the bike to pieces!
It worked out that if we bought just the engine, then the ECu, wiring, ancillaries etc it would have worked out at over £6000, and we bought the whole bike for a little over £5000 so quite a good saving and we can sell the rest of the components that we don't use on eBay.
Any tips on where to start with this ECU?
Posts: 7 | Location: Liverpool (UK) | Registered: October 25, 2006Reply With QuoteEdit or Delete MessageReport This Post
I just ran across this web site and have been looking for guys that have put this motor in carts.. I have bought the crate engine for a atv and need the electrical etc, and would appreciate if any of you have any way to contact sombody that has been down this route. Thnaks in advance Brindley
Posts: 1 | Registered: October 27, 2006Reply With QuoteEdit or Delete MessageReport This Post
How does this figure into costs? I mean, if one of these is advertised around $3-3500, is that not a large amount to be slapping onto your cost report? I mean, you could say that you took the cost of the bike, sold everything else off and took the amount you made, subtracted it from the cost of the bike this is how much it cost you in reality. Just wanted to know what you had planned?
Everthing you want is just outside your comfort zone!
Posts: 154 | Location: Leamington spa, UK | Registered: December 03, 2004Reply With QuoteEdit or Delete MessageReport This Post
RTFR ;-)
I haven't checked the 2007 rules yet but engines are costed to a displacement/performance formula AFAIK.
BTW your sig might be slightly deformed.
Tim
Posts: 14 | Registered: May 12, 2006Reply With QuoteEdit or Delete MessageReport This Post
As of 10-27-06 you cannot adjust the stock ECU. I've contacted Power Commander, and they are working on a unit, but it's not available either yet.
You're cheapest and best service quality option right now is:
Brian Lewis
Performance Electronics, Ltd.
www.pe-ltd.com
"Complete Engine Management Systems for $798"
You CAN adjust the stock ECU! ANd there isn't a lot to it either!
The standard ECU is a Welbro ECU-C unit and is fully reprogramable, and there are already a number of options for adjusting maps and TPS calibration.
1) By the official Aprilia tool, the AXONE 2000, however these are made by Texa and can be bought from Texa distributors in the UK for around £2000 if you shop around. The AXONE has everything in the one unit you could possibly need, from Osciloscope to DMM, but the cost is huge, you then need the cable (£46), the software updates (£299 a year) and the original maps. Its also a little restrictive as far as adjustments are concerned as it is a small hand held unit!
2) Albeit a Welbro ECU, Aprilia have played with the connection settings so you would have to rewrite a section of the Welbro tools software, or buy the Welbro stock ECU and connection tools (again seems a little bit expensive at around £800 for the ECU and £300 for the software).
3) Best option, TuneBoy software and cables;
http://www.tuneboy.com.au/
software including cable is £229, which has a USB plugin connection to any windows laptop (95 onwards) can log from the laptop and has full control over every aspect of the ECU. Maps are free and downloadable from there website, and software updates come free as best i know. Its also compatible with most of the engine being used in FSAE including the Honda CBR 600 and Daytona Triumph.
Trick to the Tuneboy is that they don't yet advertise that they have the software for the Aprilia XV engines as its in testing as i type and should be available within the next two weeks.
Im very much against anything like power comander on this ECU as it is so good as stock and fully customisable when you hook up using a PC, the added weight and complication of the Power Comander and the restriction of what can be done with the power comander makes it a no brainer for me. I know the trouble we had last year trying to slap a piggy back unit onto a Triumph Daytona engine and it really made the car suffer!
Have a look on the Aprilia XV forums and theres a lot of activity around the subject!
Damn, that is a sweet little motor.
only 60 lbs? yikes.
UNM FSAE 2003 to 2005
Posts: 337 | Location: Albuquerque, NM, USA | Registered: June 06, 2003Reply With QuoteEdit or Delete MessageReport This Post
Thanks for the update Vanny. 229 pounds is what? $450 US + shipping?
I make it to be about $435 and i think the price includes the shipping! Biggest bonus for us is that the same software works for last years car and adding in the triumph cable and second license key is only like another $60!
you can also pay via paypal which given its an international purchase gives some additional security! Most of the people that have discussed the Tune Boy with me have been from the US so i wonder if there is a dealer out there? Would shave a lot of time off the delivery!
I'll be ordering a copy this week and will let you know (in a new topic) when it arrives!
Hi Mechanicaldan:
I would like to know how do we can get this motor and the shipping costs to México (of couse the time of delivery) here is my email: mendieta.arturo@hotmail.com, our team (UAEMEX RACING) is interested in a complete quotation (incluiding discount program if it is available and th complete list of accesories for the motor (competition kits etc)) thanks a lot
Regards
A Mendieta J
UAEMEX Racing
Posts: 13 | Location: México | Registered: May 28, 2006Reply With QuoteEdit or Delete MessageReport This Post
Picture of e46mthree
greetings
just as an fyi, there is a good forum specifically for the Aprilia SXV/RXV motorcycles - the bikes that use this motor. lots of good experience and expertise
http://www.apriliaforum.com/forums/forumdisplay.php?f=50
regards
Posts: 1 | Registered: November 18, 2006Reply With QuoteEdit or Delete MessageReport This Post
Some more motors to came in!!! Enjoy the pictures, and don't drool too much on your keyboard. The 3 pictured are RXV 550s. The minor difference is lower gearing. See the ratios listed above.
Cheers,
Dan
Dan,
Big ups for your efforts in sourcing these engines for FSAE use. It's not easy sourcing crate engines, especially when you are going into bat for other teams as well. Good stuff.
I can't wait to see these cars on track. It would please me no end to see competitive twins, fours and singles all dicing it out for the honours.
Cheers
Geoff Pearson
RMIT FSAE 03-06
Design it. Build it. Break it.
Posts: 340 | Location: Melbourne Australia | Registered: June 17, 2003Reply With QuoteEdit or Delete MessageReport This Post
Tuneboy has this week been released for the RXV/SXV engines, it can be found on there website at £220 (more expensive than there others because you get a genuine Aprilia cable with it, and the cable alone costs some £135!!!) they will ship globally and it's worth speaking to them about Educational discount!
www.tuneboy.com.au
www.tuneboy.co.uk
I've also been speaking directly to Putolinea (people that make the recommended oil) and they seem very keen to deal, perhaps if enough people where interested in the states you could buy bulk! And if your getting engines through this thread then you should be able to find others to go in with bulk purchases?
I'll look to a new thread regarding the ECU once i have it in my hands Big Grin
Mechanicaldan, any ideas on shipping costs to the UK? I think we will be needing another engine next year, it will be the MXV with any luck, but if we can get another RXV without buying a whole bike i'd much rather go with that! Only thing we would need is the ECU and loom (or a plug!)
