FSAE.com Forums    FSAE.com Forums  Hop To Forum Categories  For Sale    Torsen Diff and Ohlins Dampers on Sale
Torsen Diff and Ohlins Dampers on Sale Login/Join
Picture of Mehul Botadra
posted
Torsen Diff -
Its a three year old Zexel Torsen Limited Slip differential. We're planning to give away the differential housing with half axles and sprocket adapter. We're looking at something around Rs. 20,000/-
Ohlins Dampers -
Shocks used are Ohlins ST 44 with the follow parameters:
1. Type Single piston double acting-oil filled Oil filled – gas reservoir
2. Length eye to eye(mm) 209 mm to 279 mm
3. Adjustability Rebound and compression
Accordingly, with a motion ratio of 0.74, the maximum shock shaft travel would be 56.4 mm.Spring stiffness is 40 N/mm.
They're in little fucked up condition and need servicing, but I feel they work pretty well! We're looking at Rs 1,50,000/-
The more you know, the more you dont know!
Orion Racing India
2008 - Random Onlooker
2009 - Bodywork Assistant
2010 - Business Manager
2011 - Team Manager
UIC Motorsports
2012 - Team Filler
Posts: 131 | Location: Mumbai, India | Registered: August 17, 2009Reply With QuoteReport This Post
posted Hide Post
Can you send me some photos of the differential?
Thanks,
Doug
Posts: 2 | Registered: July 28, 2010Reply With QuoteReport This Post
posted Hide Post
Do you still have the differential? We are very much interested. If yes could you mail me the pics on nvphadnis@gmail.com?
Thanks
“Being second is to be the first of the ones who lose" - Ayrton Senna
Posts: 39 | Registered: February 10, 2010Reply With QuoteReport This Post
posted Hide Post
Still have the dampers?
UI Racing Team
Posts: 2 | Registered: January 15, 2012Reply With QuoteReport This Post
posted Hide Post
Sorry to add to the questions, but do you have the differential output shafts still?
Cheers,
Full Blue Racing Team
Posts: 6 | Registered: February 17, 2012Reply With QuoteReport This Post
posted Hide Post
Hello,this diff is still on sale now?
Posts: 2 | Registered: August 11, 2011Reply With QuoteReport This Post
  Powered by Social Strata
© FSAE.com 2001-2011
