    FSAE.com Forums    FSAE.com Forums  Hop To Forum Categories  Dynamic Events    Maximum Tractive Effort Curve
Hi Guys,
I would like some help modeling our car for the straight line acceleration test please.
I would like to create a maximum tractive effort curve + other data with it, that makes it useful. This is so the FD ratio can be optimised.
Has anyone done this? Would anyone be willing to post an excel spreadsheet so i could get an understanding and produce my own?
Any help or advice is much appreciated.
Many Thanks
Ed Sclater
Posts: 5 | Registered: November 13, 2005Reply With QuoteEdit or Delete MessageReport This Post
I've done this, but as I'm a Design Judge I don't want to release my spreadsheet. The output graphs should appear in the presentation 'Develop to Win' on http://www.formulastudent.com soon, to give you an idea.
I will say that you will learn a lot more by producing you own spreadsheet than using someone elses. It's a straightforward problem. I will hint that you need the following data for your car as a minimum:
Torque curve, gear ratios, final drive ratio, mass, wheelbase, centre of gravity position and some form of tyre data.
Also see:
http://fsae.com/eve/forums/a/tpc/f/125607348/m/71810543821
Regards, Ian
Posts: 319 | Registered: July 15, 2003Reply With QuoteEdit or Delete MessageReport This Post
Picture of Denny Trimble
Agreed, I made one in Excel with the vlookup function, and learned a lot.
Would it also be effective if you used a weight distribution percentage?
Say you had a car that was balanced 47/53, use the 53% as a basis to develop a tractable torque curve. This is if my understanding is the usable amount of torque in each gear before wheel spin. Otherwise, could you two elaborate on what youre developing and have developed.
My spreadsheet only uses wheel torque outputs at certain rpms, and I compare them to a max amount of torque needed to produce f_staticmax (friction).
Stan Weed
UNH Precision Racing
'05,'06
Electronics Team Captain
Engine Team
General Smart Ass
Posts: 97 | Location: Durham, NH | Registered: October 26, 2004Reply With QuoteEdit or Delete MessageReport This Post
It sounds like you are on the right track there. Start with an FBD of the car and use the corresponding equations to develop your equations for propulsive force. To get an idea of actual accelerations you will need to compare the maximum force available to the maximum force the tires can sustain.
I'd post the spread sheet I've created but like the others I think it is something that is relatively easy to do and you will learn quite a bit by doing it.
Josh Gillett
Oregon State FSAE '04-'06
Posts: 343 | Location: Everett, Washington | Registered: August 25, 2003Reply With QuoteEdit or Delete MessageReport This Post
By CoG position above I meant both height and longitudinal location. Lateral can be assumed symmetric. That way you can calculate weight transfer to the rear wheels.
The only Excel functions I used are 'LOOKUP' and 'IF'. Using a simple sum to integrate timesteps worked well enough for me, just make the timesteps small...
Regards, Ian
Mainly for Ian, but if anyone else can help I would be greatful.
On your graph for modelling acceleration what governs the rate at which the RPM trace increases and the rate at which it decreases when changing gear?
Also when changing gear is the time lost about 0.2s?
Many Thanks
Ed
You'd need to factor in engine inertia and a more detailed model for clutch engagement, but it probably won't change the results much. I just use a fixed drivetrain loss percentage and a simple on-off clutch which picks up the engine torque instantly after the shift delay, seems to work OK.
For the others who have done this, do you see a significant change in ET with the final ratio? I get a difference of about a tenth of a second between 3.5:1 and 5:1 on a 4.1 ET, which is consistent with results from a Performance Trends drag racing program, but I would've expected a bigger change. Probably depends a lot on the way you handle launch.
Marc Jaxa-Rozen
École Polytechnique de Montréal
Posts: 195 | Location: Montreal, QC | Registered: September 23, 2002Reply With QuoteEdit or Delete MessageReport This Post
The way you handle the launch and also the shift times affect how the final ratio changes the ET. If you set the final drive low enough you can end up with an extra shift or two and depending on how long you have set for shifts this can negate advantages from the greater acceleration.
Josh Gillett
Ditto for the shift modelling. ET varied by less than 0.1s between final drives 2.5:1 -> 4.0:1 for 1 -> 4 shifts respectively. This is somewhat intuitive, as in general the most critical portion of launch is grip not torque limited, and the improved tractive effort curve from a short final drive is offset by the extra shifts required.
Ian
Ian
Have you guys been able to test these different ratios and verify your spreadsheet results?
How usefull do you guys think a detailed spreadsheet is vs a simple one based on torque curves, gear ratios and final drive? Most of the times in Detroit varried by more than .1 seconds for the different accel runs.
OSU FSAE 05-06
Posts: 72 | Location: Portland, Oregon | Registered: October 19, 2004Reply With QuoteEdit or Delete MessageReport This Post
Ian
Depends on your shift time. The longer the shift time the less sensitive the car will be to final drive because of the shift time offset. If you have faster shifts the final drive becomes more influential.
Obviously, unless the car is already completely grip limited at the end of the accel event, it will benefit from more tq to the wheels from a lower final drive ratio. But the shifting comes into play.
Auburn FSAE Alum 00-04
Posts: 1183 | Location: Manhattan Beach, CA | Registered: September 12, 2002Reply With QuoteEdit or Delete MessageReport This Post
Picture of Jersey Tom
Here's a dumb question.
What are you plotting on a maximum tractive effort curve? What, as a function of what?
Colorado FSAE Alum | 05, 06, 07 (C-Cpt)
Posts: 877 | Location: Boulder, CO | Registered: March 31, 2005Reply With QuoteEdit or Delete MessageReport This Post
Picture of terra_dactile
hi,
i could be mistaken but it would probably be engine rpm on the y axis and actual vehicle speed on the x axis.
correct me if im wrong,
Jude Berthault
ETS FSAE
Posts: 88 | Location: Montreal,Quebec,Canada | Registered: February 07, 2005Reply With QuoteEdit or Delete MessageReport This Post
sorry for my last post it was obviously not correct, i read the question wrong,
I believe that you compare the force created by the engine on the tire in logitudinal direction with respect to the amount of force the tire can resist with out slipping.
the latter is very difficult to know for sure since their are so many parameter s that ifluence the force the tire can resist,
but the dat we have from the tire testing consortium should guide us in the right direction,
Jude Berthault
ETS Formula Sae 2003-Current
Tractive 'effort' would be better named Tractive Force. Calculate the longitudinal force available at the contact patch and plot against vehicle speed. Usually transmission losses are included, but not any road loads. Tractive force can be converted into vehicle perfomance only by including road loads and tyre grip.
Ian
one thing I was wondering how you get around is longitudinal weight transfer. In order to know how much tractive force is available you have to know how much weight is in the rear tires, and to know that you have to know how much you are accelerating, but to know this you need to know the tractive force, etc. etc.
I suppose this could be accomplished with a simple iterative method... get one parameter on the left of the equation as well as buried somewhere in the right side, plug in a guess on the right side and see how close it comes out to the left side, and then plug the new value back in again and see if it converges. sorta like what you would use to calculate a four bar linkage.
Jeff Cortes
Posts: 55 | Location: UCSD | Registered: April 17, 2005Reply With QuoteEdit or Delete MessageReport This Post
In my opinion, the most important factor in choosing a final drive ratio is how easy it is to launch. We were able to drop our times 4/10ths of a second from 05 to 06 with similar power curves by choosing a final drive ratio that was easier to have clean launchs without excessive wheel spin.
Things like shift time don't matter all that much.
OSU FSAE 05-06
I watched many teams do poorly in accel due directly to shift times. Any shift that has an audible delay is costing you big time.
We also made improvements in our accel times by going taller on our gearing.
'01-'06 Cal Poly Pomona
Posts: 302 | Location: Huntington Beach, CA | Registered: September 19, 2004Reply With QuoteEdit or Delete MessageReport This Post
All the calculations in the world will make you feel better but the less shifting that you do on the autocross course will give the fastest lap times. The problem will always come back to the drivers ability to process information. The less things the driver has to do the better. Most FAST autocross cars have two pedels and only a temp gauge. If the gear shift lever is there at all it only has 1st , Neutral and 2ed.
AW
Posts: 96 | Registered: September 16, 2002Reply With QuoteEdit or Delete MessageReport This Post
