we are a new team on the 2009formula sae!so we donnot have many experiences in driver`s train!is someone could tell me something?
We use a local go-kart track, also try reading Drive to Win by Carol Smith.
J.R. University at Buffalo Alum. Safety Wire Team Leader "Most of the things worth doing in the world had been declared impossible before they were done." Louis D. Brandeis |
1st
safety: choose a spot that is far from posts and sidewalks, they damage the car pretty bad when you hit them, especially right before comp. Also make sur ethey always wear their safety gear, helmet suit and arm restrains!!!! 2nd Try and find the best surface you can get, nice smooth big open parking lot, the better the asphalt the beter chance you have to break your car before comp which is esential. 3rd make a track by the rule of comp, no point it being wider or less then comp otherwise it is not good for drivers as they might get habits that dont help in comp. 4th Every cone they hit equals 1 big kick in balls, they learn pretty fast not to hit the cones!!! 5th Recruit competitive karting drivers from your school, those that have driven in some sort of comp can perform under stress, actually real driver get better the more stress thier is. 6th Make sure that you dont just let the guy or girl that designed the most of the car drive, usually the driver skill is inverly proportionate to their inteligence!!!! Jude Berthault ETS FSAE 2003-Current Vehicle Dynamics |
Don't get into the habit of sending each driver out there to see who gets fastest lap. That will do you no good in endurance. Make sure your drivers push hard right out of the gate and do not hit cones. Overall time is much more important that fastest lap.
Simulate each event a competition and do it often. Even acceleration takes some practice When the difference between a good time and a bad time is .2 seconds over 75 points, IT MATTERS! John "Jack" Vinella University of Washington Alumni 06' 07' 08' 09' |
We found gokarting to be extremely beneficial in choosing drivers and continuing to train them. It's also a great social activity to keep the team interested. They're simple enough to let your drivers focus on learning lines and throttle control before stepping up into the FSAE car.
-------------------------------------------- Technical Director UARC 2007 http://formula-sae.adelaide.edu.au |
another thing that you can do is look at track data. Two drivers will almost always be faster or slower than one another in different parts of a course. If you have data, you can compare lines, brake points, etc. and the two drivers can help each other get faster.
Tough statement. OK, take a look at Montoya, or Jimmy Vasser, they fulfill your theory exactly But on the other hand, how dumb must have been a Senna or how wise a R. Schumacher??? DART Racing e.V., Darmstadt Alumni Technical Director Suspension & Brakes 2005-2007 Brake System Developer 2005 - 2008 CFRP Rim Specialist 2008 Test Team and Driver 2005-2009 Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere. Colin Chapman |
I'd be pretty keen on seeing what other teams are doing regarding this as well since it's kinda been part of my job as testing manager this year.
Also has anyone got any good info on using datalogging to train drivers? This year is the first time that we've been able to implement it. We mainly use throttle pos, brake press, steer angle and lat and long accelerometers. Is there anything else that would be handy. Also anyone got any good resources for using data to train drivers? We basically just compare plots from different drivers to try and work out where times can be improved. Cheers, Tommo http://www.uarc.com.au/ UARC '09 Intake and Exhaust / Drivetrain Leader UARC '08 Electrics UARC '07 Aero and Body |
I recomend the Racecar Data Acquisition book that is available on the SAE website. It talks a lot about what the data means, how to improve the driver, and is very easy to read. It is more of a baseline book, not really in depth, but does include calculations and such. I really recommend it. Ben Louisville Motorsports Formula SAE 2010-2011 Team Principal/Chief Engineer 2010 Lead Chassis/Suspension Designer 08-09 Brake Designer |
There was a comment about setting up a "competition course". If you have trouble getting cones try asking a local autocross group or even construction company to borrow some on your test days. We have found this to work well for us.
At the most basic level, make sure that you practice the events like they will be at competition. This means, full safety gear, arm restraints, full cones (inside and OUTSIDE of skidpad). Even good drivers sometimes choke, so it’s good to get them very used to the events so there is less pressure the day of the events.
Practice tight autocross courses with minimum radii turns and slaloms. I hate this, it sucks, is not fun, etc. but SAE courses will have these aspects to them, and you can really loose a lot of time if you find that your car can't steer enough or that the steering is too heavy. Unless you don't have a choice, I would not start new drivers out in the fsae car with slicks. Slicks are tough to drive on (and expensive!) and also, slicks plus lots of power can be disastrous because there is very little room for error before the tires slide out. Coupled with parking lots, curbs, poles, it can be dangerous. I agree with the other poster that go karts are a good starting spot and even I learn a lot from them (running endurances and such). Good luck, be safe. |
I hear that some teams physically train there drivers and put them on special diets to lose weight. Guess that what you have to do to win west.
no more weight loss for me anymore...we figured out that with more weight our tires get hotter and I pull more g's. Or I really like chipotle.
chipotle does give you that extra thrust, seems to be working for the Brawn GP cars:
Brawnpace secret! Neil Schreiber Missouri S&T Racing '05 - '08 http://fsae.mst.edu/ *formerly University of Missouri-Rolla |
Our best driver is 200lbs and about 6'2". Like i said its still baller that you did that. |
I would put a clock on a kart driver. Make sure they are consistent every lap. I want to see aggressive, smart driving and that driver has to take chances like no other.
You find those two traits, make sure they do not burned out too soon or have "seat gap" like Smokey Yunick said is a fearless driver that does not worry about death or family is win at all costs. |
I really don't think that has anything to do with autocross speeds.... |
Can't really add much more to what people have said. It is well worth getting in someone who knows what their doing to cast their critical eye over the drivers. Whether that's just an alumni who was a good driver, or someone else you know who races karts/cars professionally, it will help identify the areas they can improve massively.
Spending just half a day with someone instructing you can teach you stuff that would take literally years to identify yourself. If they refuse to listen, they're just not ever going to be fast. Any good driver will tell you they never stop learning! An alternative to finding a good driver would be to get someone who's good with telemetry to have identify areas of improvement. Not quite as good, but better than nothing! Triumph Motorcycles Chassis Design Engineer FSAE '05-08 UBRacing 2008 Technical Director and Sprint/Endurance Driver 2007 Powertrain Team Leader and Sprint/Endurance Driver |
This is how we do it in Iowa:
X-Treme Driver Training Oh yeah, lots of good other info here from others...except the whole "aggressive, no chances" thing. I've seen many aggressive drivers, and I've seen several fast drivers, but I have only a couple drivers that were aggressive and fast, and they both did a lot of off-road racing. Chances are if they spent some more time on pavement and mellowed out, they'd probably be faster. Aggressive drivers are most often good at nothing but making team leaders angry and destroying a perfectly good set of tires. And if you really need a fearless driver, that doesn't worry about death or family...you've got something SERIOUSLY wrong with your car. Iowa State University http://www.sae.stuorg.iastate.edu/?page_id=93 U.S. Army Field Artillery Platoon Leader, Afghanistan '10-'11 Technical Director Fall '07, '08-'09, '09-'10 Suspension Team Leader '06-'07 Random Grunt '02-'06 |
+1 You also have to think about what event they will be driving in. You want the smooth/consistent drivers in the endurance and the fastest in the autocross. If you have a fast but erratic driver in the endurance they will cause hell for your tires and brakes. Robby Sampson 2010-11 Chassis Technical Lead "Speed has never killed anyone, suddenly becoming stationary… that's what gets you." -Jeremy Clarkson |
| Powered by Social Strata | Page 1 2 |
