    FSAE.com Forums    FSAE.com Forums  Hop To Forum Categories  Wanted    F4/F4i clutch basket
Hello,
We need a F4 or F4i clutch basket ASP.
jeromedesrochers@hotmail.com
Thanks
Jerome Desrochers
Engine team leader
Formula SAE of Sherbrooke
Powered by CVT
Posts: 7 | Location: Québec, Canada | Registered: September 12, 2002Reply With QuoteEdit or Delete MessageReport This Post
Which one? Big difference...
I just need enough to tide me over until I need more.
What the difference between the two?
We don't care about the basket itself, we will only just keep the gear. Correct if i'm wrong, but I think the gear is identical for the F4 and the F4i.
Jerome Desrochers
Engine team leader
Powered by CVT
Different basket, different gear, different pin, different cover, F4i has one more plate than the F4 clutch. Trans shaft is longer on the F4i.
You can swap the clutches but it causes some problems. I wouldn't recommmend it.
Yes the gears are different, the F4i has a wider gear. Still works, kinda. Not sure if the F4 would work in the F4i but the F4i fits in the F4 O.K.
[This message was edited by Charlie on February 17, 2004 at 02:38 AM.]
