    FSAE.com Forums    FSAE.com Forums  Hop To Forum Categories  Wanted    torsen differential required
hello guys, this is aious racing team from india .we have tried to contact torsen company many a times . but they are not responding .we are midway through the construction of our car and we urgently need a reasonably new lsd differential
aious racing team india
 www.aious.in
www.aious.in
Posts: 7 | Location: new delhi | Registered: March 01, 2008Reply With QuoteEdit or Delete MessageReport This Post
Picture of PatClarke
Aious,
Read this article,
http://www.formulastudent.de/academy/pats-corner/advice...ts-column-january-2/
Pat
Jorge Agustín Nicolás Ruíz de Santayana y Borrás wrote: "Those who do not learn from history are doomed to repeat it."
Posts: 536 | Location: Sydney | Registered: October 13, 2002Reply With QuoteEdit or Delete MessageReport This Post
Picture of J.R.
Pat, Possibly a dumb question, as I am new to suspension, but when tuning rear slip angles with a solid rear axle, can you achieve the same, or close to the same turning power as with double wishbones and a spool? I am just starting to look at our tyre data, and any advice for this setup would be appreciated!
Also, we are running Hoosier 20-6x10's, which appear to be only mildly camber sensitive. This is why I would assume that we can get nearly the response out of the tyres, without having to worry about the laden wheel cambering out.
JR
John M. Robinson
University at Buffalo
Safety Wire Team Leader
Posts: 15 | Location: Buffalo, NY | Registered: January 05, 2008Reply With QuoteEdit or Delete MessageReport This Post
JR,
Absolutely!
A fantastic demonstration was when the University of Queensland car smoked the field in the Dynamic events at FSG 2006.
This car was a fairly standard spaceframe car with A arm and pushrod suspension.
Once one gets their head around the differential slip angles required and how to generate them, these cars work very well.
Not only that, but it's a good way to take some significant mass out of the car and a significant cost saving.
Something well worth investigating.
A word of warning. If you turn up at the comp with a spool, you better have some good reasons why, because the Judges will really grill you!
Search the archives here. There have been several pertinant posts by the original UQ team.
Pat
