    FSAE.com Forums    FSAE.com Forums  Hop To Forum Categories  Open FSAE Discussion    wiring doubts
hi everyone
its my first doing the wiring and i would like some tips. I have serchead but i couldnt find a table to size the wires, for example:
current(A) X section (mm² or AWG). Should i use the table or take in count the voltage drops and use a formula?
Posts: 23 | Registered: January 10, 2008Reply With QuoteEdit or Delete MessageReport This Post
It really depends on the wire - it should come with some sort of datasheet about it. Remember than length is a large factor - if it's a very short length you can get away with thinner wire, but I wouldn't push it too much.
We use tefzel wire, and use mostly 22 gauge, with 20 gauge for higher current things such as our waterpump and radiator fan. I'd like to have run 24 gauge for the large number of sensor wires running to the datalogger, but we were unable to get a roll of it in time before the car running goal and resorted to 22 awg again.
Posts: 2 | Registered: September 08, 2008Reply With QuoteEdit or Delete MessageReport This Post
Hey,
Just adding on to that, a quick search on google gives us a general chart of wire gauges to current capability. These charts, however are just a rule of thumb, and it is always prudent to consult the datasheet of the wire.
http://www.cablesandconnectors.com/wiregauge.html
http://wiki.xtronics.com/index.php/Wire-Gauge_Ampacity
Basically, you'd be interested in specifying wire that's about 1.5 to 2x your potential peak current flow. As analog sensor data doesnt go past an amp, we selected 24 gauge to work with. Only reason why we did not go above 26 gauge is that above AWG24, wire becomes really hard to work with and crimp, i.e. fiddly.
Hope that helped.
Richie Wong
Electron
University of Auckland FSAE
Posts: 2 | Registered: July 23, 2008Reply With QuoteEdit or Delete MessageReport This Post
Picture of Marshall.Hagen
It would be wise to add shielding by means of twisted pair or shield wrap around any crank/cam position sensors and coil/injectors. We had a problem on our last car with interference from the starter causing us to drop camshaft position during cranking, which made starting a hassle.
WWU F-SAE
Engine/Drivetrain Captain
Posts: 25 | Location: Bellingham, WA | Registered: February 20, 2008Reply With QuoteEdit or Delete MessageReport This Post
Picture of Chris Lane
Make sure you heatshrink your final loom. We use Raychem. Looks really neat too!
Kind Regards,
Chris Lane
Design Team Leader - ECR 2008
http://engineering.ecu.edu.au./ecr
Posts: 173 | Location: Edith Cowan Racing, Joondalup, Western Australia | Registered: September 13, 2007Reply With QuoteEdit or Delete MessageReport This Post
Raychem is awsome quality stuff. But it can be expensive if you don't have good hookups. If a team is really tight on money their is nothing wrong with using high quality electrical tape. Just take time wrapping it up and if you do a good job it will still look really neat.
UniSA 07
Posts: 24 | Registered: August 20, 2007Reply With QuoteEdit or Delete MessageReport This Post
Picture of Dan G
There are some excellent wiring tips posted in this thread...
http://fsae.com/eve/forums/a/tpc/f/125607348/m/25010656541
__________________________________________________
Honeywell Turbo Technologies - FSAE Sponsorship Guy
UMich-Dearborn '04-'06
Carnegie Mellon '99-'03
eVil eNgineering.com | '95 M3 | '93 325i | '87 944 | '86 951
Posts: 425 | Location: Hermosa Beach, CA | Registered: April 15, 2003Reply With QuoteEdit or Delete MessageReport This Post
Picture of Steve O
Originally posted by Prohet][:
...their is nothing wrong with using high quality electrical tape. Just take time wrapping it up and if you do a good job it will still look really neat.
Agreed, but still use a heat gun or a soldering iron to melt the end of the electrical tape; electrical tape will start to peel and allow for no protection and not to mention you will get that black glue all over everything. By melting it to itself (CAREFULLY), you will prevent this from happening. This is a professionally accepted practice, I work for the electric company and see it done in relay wiring all the time wherever electric tape is used.
Steve
Posts: 130 | Location: Hartford,CT | Registered: September 24, 2007Reply With QuoteEdit or Delete MessageReport This Post
