    FSAE.com Forums    FSAE.com Forums  Hop To Forum Categories  Open FSAE Discussion    single cylinder engines
Page 1 2 3 4 5 6
Our WR426 had a kick start, we fitted some italian electric-start kit. The quality of the kit was marginal. The 450 has electric start so that shouldn't be a problem.
Lehigh Formula SAE 1999-2004
Posts: 241 | Registered: September 12, 2002Reply With QuoteEdit or Delete MessageReport This Post
Ducati monsters are 90deg twins!! Not singles.
Chris
Engine/Drivetrain Leader
UNSW FSAE
Australia
Posts: 16 | Location: Sydney, Australia | Registered: March 15, 2004Reply With QuoteEdit or Delete MessageReport This Post
Originally posted by jonno:
I don't really like the idea of air cooled engines... whilst they are basic and increase the simplicity of things, I can't see without impressive ducting (or with the single head tilted out to one side) how you can get a good airflow behind the drivers seat. Teams do run them, so they do get them working though. any teams run an aircooled?
Most performance "air cooled" engines are really oil cooled. They've got a wee oil cooler. It seems like you could have a more efficient system overall, since the oil can be hotter than water, and hence lose more heat.
Posts: 253 | Location: Seattle, WA | Registered: September 19, 2002Reply With QuoteEdit or Delete MessageReport This Post
so for the single cyls oil cooling is well important. i heard the bikes run the oil round the inside of the frame to dissipate the heat.
where can i found out how much heat needs losing from the oil? does the enigne have a thermostat for the oil?! would it be possible to fit one? What are the dangers of the oil being too hot or cold?
any ideas?
dan
Posts: 16 | Registered: October 08, 2004Reply With QuoteEdit or Delete MessageReport This Post
Picture of jonno
The wr450 uses the frame at the front as it's oil storage, it is the portion of the frame that runs up from the lower front engine mount up to the steering pivot, a long tall column basically. either side of this in front of the bike riders knees are the two water radiators, so it's obviously where yamaha believe to be best for airflow over it.
For our install on the car we are running with the oil tank off the yzf450 quad (basically the same engine): we're intending on rejecting all heat by the water cooling system... the oil tank is partially in the airstrea though so will be cooled. It's all logged on the dyno though so any problems will instantly flag up over the next few days
Jonathan Gray
Brunel Racing Team Principal 2004 - 2005
Posts: 127 | Location: Uxbridge | Registered: August 24, 2004Reply With QuoteEdit or Delete MessageReport This Post
any ideas?
dan
Engines start with the oil cold, and unless you're doing something crazy it won't be too cold.
They make oil thermostats, I've used one for a temp gauge for air cooled VW's.
about singles,
jawa engines have no transmission and make most of their power because of the methanol.
the 450s yamaha and honda, there are kits to make them 505 for AMA dirttrack racing but i know that the honda can be a 530 because the quad engine has an availible big bore kit. there is also a crank available that would make a stock motor into a 505, add this to the 530 kit and you are into the 600 range.
the honda CRF engine/trans is absolutely a terrific motor except the intake valves are hard coated Ti and as soon as you wear off the coating bye bye intake valves.
the yamaha is equally potent but i know less about them.
stay away from cannondales! i worked for a company that bought out cannondale ,,, junk...
eventhough they have fuel injection.
life is a hole dig it
Posts: 1 | Registered: March 02, 2005Reply With QuoteEdit or Delete MessageReport This Post
I have heard power ratings of singles stock over and over, but does anyone know the power of a FSAE restricted single? What does the torque curve look like?
I just don’t see how the power to weight ratio of a single would be superior to a 4 banger.
Posts: 29 | Registered: January 17, 2004Reply With QuoteEdit or Delete MessageReport This Post
I make 38 HP with a 2002 Suzuki LTZ400 - I wouldn't really recomend a single, starting can be diffcult, they can kick back an blow your starter clutch, and they make way more noise than a 600/4.
Also since the 600's are designed to take 100+ HP they can the clutch and tranny/rods can take 75HP all year with no probs.
Howeve my engine was designed with 32 stock and I'm up around 40 HP now, things break/bend/wear out faster - I go through clutches all the time.
I dont know how those formula student guys ran the acceleration so fast...
Bruce
http://engsoc.queensu.ca/formulacar/engine/
BB
Posts: 56 | Location: Kingston ON, Canada | Registered: March 03, 2005Reply With QuoteEdit or Delete MessageReport This Post
acceleration isn't only about HP
Posts: 23 | Location: Delft | Registered: November 04, 2004Reply With QuoteEdit or Delete MessageReport This Post
What teams have been sucessfull with singles?
Royal Melbourne Institute of Technology (RMIT) won Student with a single.
Cheers
Ben Inkster
UWA Motorsport
University of Western Australia
Posts: 45 | Location: Perth, Western Australia | Registered: September 30, 2004Reply With QuoteEdit or Delete MessageReport This Post
IMO you should lose 50 points for terrible sounds whilst using a single
Posts: 765 | Location: Brisbane,Queensland | Registered: January 30, 2003Reply With QuoteEdit or Delete MessageReport This Post
Everybody's got an opinion Frank!
RMIT produce roughly 60hp rear wheel. Not only have them won FS, but they also come second in FSAE-A 2004.
Remember, there's no right or wrong, just different!
Posts: 76 | Location: Melbourne, Australia | Registered: May 16, 2003Reply With QuoteEdit or Delete MessageReport This Post
Picture of Igor
Delft and Tokyo Denki were doing very well with their singles at the Formula Student event. Delft was actually first in points before a wiring problem ended the endurance.
And if Delft can do a 4.12 second acceleration with a single it's hard to argue there isn't enough power.
Igor
ps next week you can watch our new Spyker at Sebring :-)
Posts: 179 | Location: Netherlands | Registered: November 16, 2002Reply With QuoteEdit or Delete MessageReport This Post
Come on guys, you all know its got nothing to do with power by itself, its a power to weight thing. you have to look at the whole package, we built a 169kg car with a 60hp single.......you do the maths. not to mention the increased drivability of a single!
ash
Posts: 126 | Location: Geelong, Victoria, Australia | Registered: January 29, 2004Reply With QuoteEdit or Delete MessageReport This Post
Originally posted by Ashley Denmead: not to mention the increased drivability of a single!
Maybe you should mention it, what makes it easier to drive exactly?
Auburn FSAE Alum 00-04
Picture of Denny Trimble
Well, if you can floor it and the car doesn't spin, that's driveability!
Just kidding... Smile
I think the lower weight (especially when coupled with other design choices) allows the tires to work better, so even with a lower power/weight ratio, a single car might be quicker. But, we'll find out about the tires in June, at least those teams that sign up for the testing will!
Ok if you havnt figured out what i meant by better drivability then i'll try and explain.
im sure were all aware of the circle of traction......
a single cylinder engine has one powerstroke for every 720degrees of crank rotation, where as a 4 cyl has a powerstroke every 180 degrees of crank rotation. with this in mind a four cylinder engine puts a forward moving force into the tyre 4 times as often as a single cylinder. Due to the tyre not being worked as often to produce forward motion there is more lateral grip available for cornering.
hope this explains what the heck i was on about earlier.
Another argument for singles is that some people believe they are more forgiving on driver error as they dont penalize the driver as much if the wrong gear is selected due to their low down torque and pulling power as compared to a high revving 4 cylinder 'Power engines'.
Anyway compromise is the name of the game......Just build the damn car and worry about making it go fast later Wink haha
cheers
ash
Ash,
Excuse my ignorance but ...
I am having difficulty seeing how lowering the longitudinal loading frequency and increasing its amplitude increases lateral tyre loading capability.
Unforunately my knowledge of tyre frequency behaviour is pretty minimal. Did you pick this up from a reference or testing or is it more of a reasoned explanation?
I have heard a similar explanation from other people running singles and I am getting more and more curious as to where this theory cam from.
Kev
UWA Motorsport
Posts: 248 | Location: Perth, Western Australia | Registered: September 12, 2002Reply With QuoteEdit or Delete MessageReport This Post
 Previous Topic | Next Topic powered by eve community Page 1 2 3 4 5 6
