    FSAE.com Forums    FSAE.com Forums  Hop To Forum Categories  Open FSAE Discussion    Steering with bearing.
Hi every one! I am new in the big world of fsae and this year I'm designing the direction system. My question is, do you guys use bearing for the steering shaft or only bushing? Depending on your design why are you using that? Thanks
Polytechnique de Montréal
EPM 2009
Posts: 1 | Registered: September 28, 2008Reply With QuoteEdit or Delete MessageReport This Post
We use a teflon bushing turned on a lathe...it works well as long as its supported well...If it isn't then you'll get lateral play in the steering wheel.
Posts: 9 | Registered: July 18, 2008Reply With QuoteEdit or Delete MessageReport This Post
On our steering shaft we have a lightweight spherical bearing. Easiest solution I think.
Posts: 12 | Location: Ryerson - Toronto | Registered: September 24, 2008Reply With QuoteEdit or Delete MessageReport This Post
Picture of Píco
We use 2 small ball bearings...smooth steering, no play in the shaft
Philippe
Technical Director 07-09
McGill Racing Team
"Everything should be made as simple as possible, but not simpler." A. Einstein
Posts: 11 | Registered: September 23, 2008Reply With QuoteEdit or Delete MessageReport This Post
we have used a large composite spherical in the past... now we use a thin roller bearing
Posts: 122 | Registered: January 31, 2007Reply With QuoteEdit or Delete MessageReport This Post
we run a deep groove ball bearing on our steering column....though I am not sure what the new team will be doing next year...
Finished @ UofT Racing
2003-2007
www.fsae.utoronto.ca
Posts: 212 | Registered: July 09, 2003Reply With QuoteEdit or Delete MessageReport This Post
Posts: 343 | Registered: July 15, 2003Reply With QuoteEdit or Delete MessageReport This Post
