    FSAE.com Forums    FSAE.com Forums  Hop To Forum Categories  Open FSAE Discussion    drivetrain
I am a beginner ,and i need to know whether hollow axles can be used and if yes,probably what material should i use.
Posts: 7 | Location: kj somaiya | Registered: June 25, 2008Reply With QuoteEdit or Delete MessageReport This Post
I personally have seen it done.
Many materials are possible:
Carbon Fibre (RMIT)
Aluminium (UNSW)
4140 (whole bunch of people)
Materials choice depends on your selection criteria and mechanics analysis of the problem.
With your analysis it should be possible to determine an adequate cross-section for the specifics of the load.
Then you figure out if a hollow section has any benefits.
2006 QUT Motorsport
2008 University of Waterloo FSAE
Posts: 36 | Registered: April 29, 2006Reply With QuoteEdit or Delete MessageReport This Post
@ kirby
can aluminuim be used as a material for axles....has any one done it....please give me any information on this if u have....
Engineers have calculated shear stresses for years, yes. You can do the same!
T*r / J, bro.
Posts: 377 | Registered: August 19, 2007Reply With QuoteEdit or Delete MessageReport This Post
Originally posted by sahil:
@ kirby
I saw a team do it. The first time they tried to drive the car it was heading up hill when they let the clutch out it started rolling backwards. So my engineering judgment tells me its not a good Idea.
Posts: 14 | Location: Charlotte | Registered: May 19, 2008Reply With QuoteEdit or Delete MessageReport This Post
mtg
I've seen a lot of steel halfshafts break also. Does that mean you shouldn't steel either?
Matt Giaraffa
Missouri S&T (UMR) FSAE 2001 - 2005
Posts: 324 | Location: Englewood, CO | Registered: February 13, 2003Reply With QuoteEdit or Delete MessageReport This Post
Picture of The AFX Master
Titanium is also a wonder.. but it will break your wallet and your cost report. And if you're not careful, being Ti notch sensitive (correct me if i'm wrong, i think i did read something like that at the forum), you can end breaking the Ti shaft at splines. nevertheless a bad heat treated and/or machined 4340 shaft will fail anyways
Technical Director 08-09
Team FSAE USB
Some guy on the forum said:
I always wanted to be sponsored by a strip club or sex toy manufacturer.
Posts: 97 | Location: Somewherebourg | Registered: February 21, 2007Reply With QuoteEdit or Delete MessageReport This Post
@ kirby
Thats where good analysis is important.
on the same comment as mtg, there was those bad batch of professionally made steel taylor race drive shafts that weren't heat treated properly and had a tendency to twist quite badly.
All the examples I cited above I witnessed working quite well.
Sahil,
I'm going to assume that when I mentioned aluminium axles in my original post you didn't realise I also cited a team; UNSW.
Thats probably my fault, for not being "international specific".
From my own photo collection here is the University of NSW team car ('06 I think), they have successfully run this arrangement for several years.
Please note: While I am (and most people here) are happy to share information of this nature, you will definitely not find people on this board to do work for you. And you will be informed of this if you ask.
That said I hope that this thread has got some cogs turning in your head so you can actually go do some engineering on the subject.
EDIT: And while we are on the subject, in the hopes of improving the quality of this board, please work on making your post titles more descriptive in the future.
2006 QUT Motorsport
@ Brian we have run aluminium driveshafts since I believe 2001, with proper testing there is absolutely no reason that it cannot be done in a simple manner.
@ Kirby, close, its actually our 2005 car.
2008 Team Leader Redback Racing
www.redbackracing.unsw.edu.au
Posts: 5 | Location: UNSW - Sydney, Australia | Registered: August 07, 2008Reply With QuoteEdit or Delete MessageReport This Post
What about weight?, compared to a standard 3/4" x20" hollow steel driveshafts? (9mm hole)..as for example these made by Taylor Race?.. Seems interesting Big Grin
I don't see the pic very well, do you weld the shaft to the CV plate or that have some sort of spline or such?
Team FSAE USB
TG
Picture of TG
Originally posted by Kirby:
Tom, a little off topic here but seeing this I must asked if you have noticed any side loads from the flex joints you're using? The reason I ask is that the carriers (more specifically their attachment) do not look like they'd be able to handle any lateral loading of any kind.
Posts: 219 | Location: Tempe, Arizona | Registered: February 08, 2005Reply With QuoteEdit or Delete MessageReport This Post
The shafts are welded to the endplates. There is a non-trivial lateral load carried by the endplates, but I should point out that endplates made to that design from 5000 series aluminium have been perfectly useable for many times the length of an enduro run.
CAN ANY ONE SUGGEST ME SOME BOOK WHICH I CAN READ AND KNOW ABOUT THE BEST MATERIAL THAT I CAN USE FOR MY AXLES
Picture of Mike Macie
Any engineering mechanics book will help you to calculate the stresses involved. You can't just pick a good material and hope it doesn't fail. That's not how engineering is done.
Mike Maciejewski
UB Motorsports Alum
Posts: 48 | Location: Buffalo | Registered: December 04, 2006Reply With QuoteEdit or Delete MessageReport This Post
thanx a lot for the help......
ben
Picture of ben
You're at Uni right? basic engineering shouldn't be taught to you on a forum.
What's the load? Determine a part geometry, calculate the stresses add a safety factor. Will the stuff yield? Even if it doesn't yield is it stiff enough?
Repeat for each component and you'll soon have a car...
Ben
Senior Design Engineer (Le Mans Series) - Dunlop Motorsport
Alumnus of University of Birmingham
www.ubracing.co.uk and Formula Student Design Judge
Posts: 619 | Location: Birmingham, England | Registered: September 15, 2002Reply With QuoteEdit or Delete MessageReport This Post
Dammit. I should label my photos better.
Thinking about it, was it in '06 that you moved to a spool (the "infinite-bias-diff"). I'm trying to remember...the rear bulkhead design was quite different as well.
I do remember talking at length with your drive-line guy about the flex-plates.
2006 QUT Motorsport
Aluminum can be used. Proper drivetrain engineering always results in solid steel shafts for 3 reasons.
1) For the same torsional strength, solid driveshafts have the least torsional stiffness. This decreases transmission and other drivetrain stress, which increases reliability and decreases required weight elsewhere.
2) Heat treated steel can be much more then 3 times stronger per lb then aluminum but still only weighs 3 times more.
2b)Higher yield strength means smaller diameter, lower stiffness shafts still meeting strength requirement. Basically back to #1.
3) Additonal treatments can be done to steel like shotpeening, carbonizing, and nitriding that can build compressive stresses into the material and make the higher stressed area (surface) even stronger for even more additional strength and fatigue resistance. Back to #1.
'engine and turbo guy'
Cornell 02-03
Posts: 479 | Registered: August 02, 2004Reply With QuoteEdit or Delete MessageReport This Post
Yep 2006 was the first year with the spool and the bulkhead went on a reasonable diet as well.
tom, do you machined your bulkhead or casting?
RiNaZ
Posts: 470 | Location: daytona beach, FL | Registered: July 09, 2003Reply With QuoteEdit or Delete MessageReport This Post
