    FSAE.com Forums    FSAE.com Forums  Hop To Forum Categories  Open FSAE Discussion    About aluminium pedal box
Hi, I am Akash Mody
We are a team of students participating in the Formula Student Competition. Our team name is Orion Racing India and our website is: www.orion-racing.com
We will be participating in the Formula Student Germany competition for the third year in 2009.
we are planning to manufacture pedal box and pedals completely made up of aluminium.
what should be the designing constraints i should be lookout for.
Also, what do you think if we use only stainless steel flexible brake linings with T-joints
Akash Mody,
Braking System Head,
Orion Racing India,
K.J. Somaiya college of Engineering.
+91 9867415444.
Posts: 2 | Location: Mumbai,India | Registered: September 25, 2008Reply With QuoteEdit or Delete MessageReport This Post
Picture of J.R.
Make sure it's stiff, the driver puts out a lot of force when he/she panics and slams on the brake. Also, if it's got compliance, the brake pedal looses its "feel" and the driver will have a tough time knowing just how much brake he/she is actually applying.
John M. Robinson
University at Buffalo
Safety Wire Team Leader
"Most of the things worth doing in the world had been declared impossible before they were done."
Louis D. Brandeis
Posts: 83 | Location: Buffalo, NY | Registered: January 05, 2008Reply With QuoteEdit or Delete MessageReport This Post
everything should be secondary to stiffness....a flimsy one that weighs 1/10th of the stiff one is not worth the weight saving. Because if the driver does not feel confident on the brake the car will be slow regardless. And we've had a version of the pedal tray before that it was so flimsy that we are actually flexing it more than putting actual force and building pressure in the line. We were having issue locking brakes, then we stiffenup the pedal tray and the problem went away.....
Finished @ UofT Racing
2003-2007
www.fsae.utoronto.ca
Posts: 212 | Registered: July 09, 2003Reply With QuoteEdit or Delete MessageReport This Post
While you can make an aluminum pedal tray work I would recommend against it. The small weight savings there won't really be worth it. I can say from experience like others have said here the name of the game is stiffness. The big thing to remember with driver inputs is that its not the force required at the pedal face to lock tires, its the force that someone can exert when they panic and slam as hard as they can. While it should not take more than 150lbs to lock your tires certainly someone might exert more on that pedal. Just something to keep in mind.
Scott Mingay
Rutgers FSAE
Suspension Team Leader
Posts: 34 | Registered: September 06, 2007Reply With QuoteEdit or Delete MessageReport This Post
Picture of Steve O
We used an aluminum plate last year on our car. To confirm the suspicions of the above posters, it flexes and we are doing something different this year.
Posts: 130 | Location: Hartford,CT | Registered: September 24, 2007Reply With QuoteEdit or Delete MessageReport This Post
Picture of Píco
We usually make a steel box of 0.75 square tubing with aluminium pedals. This year we had some folded sheet steel brackets that were badly welded and started to crack during brake test. The support has to be strong.
Philippe
Technical Director 07-09
McGill Racing Team
"Everything should be made as simple as possible, but not simpler." A. Einstein
Posts: 11 | Registered: September 23, 2008Reply With QuoteEdit or Delete MessageReport This Post
yea, steve o is right on that one...we (Hartford) used a 1/4" laser cut aluminum plate and it yielded BIG TIME in and around the master cylinder mounting flange. The plate was visibly bent after fsae west, and to boot it clearly flexed when a design judge stomped on the brake (he was not happy about the flexing either). In my opinion steel tubing is the best bet for pedal mounting
Posts: 9 | Registered: July 18, 2008Reply With QuoteEdit or Delete MessageReport This Post
For the past several years we have mounted our pedals directly to an aluminum honeycomb panel that was bonded into our space frame. The pedals were bolted through the panel with an appropriate "backing plate" on the other side. Even with this set up the panel noticeably flexes and creates a "mushy" feeling.
Posts: 12 | Location: Ryerson - Toronto | Registered: September 24, 2008Reply With QuoteEdit or Delete MessageReport This Post
We have a billet aluminum pedal tray that slides between two square steel frame rails. It's 3/4" billet, and considerable FEA iteration has been put into it. There is no detectable deflection (by foot anyways, there surely is by dial indicator)
Look at the Tilton pieces for example, it's where our ideas came from.
The specific modulus of steel & aluminium are very similar. Therefore the success or failure of a pedal box is down to the designer not the material...
Regards, Ian
Posts: 343 | Registered: July 15, 2003Reply With QuoteEdit or Delete MessageReport This Post
