    FSAE.com Forums    FSAE.com Forums  Hop To Forum Categories  Open FSAE Discussion    Pneumatic Clutch
Has anyone attempted to design a pneumatic clutch actuation system for their car? I ordered a piston from Bimba and I plan to use it to pull the clutch cable. But I want to control the flow rate coming out of the piston with a miniature proportional valve. I want to know if anyone has tried using a similar system and if it has worked? Thanks.
Joe Santore
The Cooper Union
Posts: 3 | Location: New York | Registered: September 22, 2008Reply With QuoteEdit or Delete MessageReport This Post
Controlling the flow out of the clutch cylinder sounds good for launches, but the flowrate would need to change for different track/tire friction. Not only different tracks, but tire and surface temps.
We used a pneumatic clutch for an auto clutch on downshift, but we also had a manual clutch for launches and such. I recommend this. There are some teams that use just a pneumatic clutch with a flow control. Kansas seemed to have pretty good luck with theirs.
I would mount the cylinder directly to the clutch lever on the engine, rather than the cable. If not, make sure the cylinder bottoms out before the cable stops pulling.
Matt Brown
Alum
U. of Oklahoma
http://sae.ou.edu
Posts: 158 | Location: Valencia, CA | Registered: April 19, 2005Reply With QuoteEdit or Delete MessageReport This Post
MST has a similar system that you are talking about. They pretty much have to launch the car full tilt every time they want to move it. We ran a similar clutch setup to Matt's with reasonable success (well at least with respect to the clutch).
-WJ
Posts: 51 | Location: Clemson University | Registered: February 02, 2006Reply With QuoteEdit or Delete MessageReport This Post
Will the valve be servo controlled? I ask because if you have a slow clutch release, you won't get
your best shift times.
I'm unsure if there are anything more than binary solenoids available for air that aren't prohibitively expensive/heavy.
You could run two solenoids, one with a valve. Heavier though. You could also (if you could find a variable electronic valve) just run a voltage decay circuit and adjust it with a pot for track adjustment.
Picture of Erich Ohlde
advice from the pro (without trying to sound too much like a prick Wink)
on the kansas car we run a bimba cylinder with two solenoids. one that controls air into the cylinder and one that controls air out. the 'exhaust' solenoid has a straight dump to atmo and a flow controlled needle valve outlet. for launching we use the flow control and for regular down-shifts we use the straight dump. it works very very well. I think wisconsin uses a dental solenoid (for nitrous oxide in the dr. office) that has a pulse width modulated control to vary the speed of the bleed off.
Erich Ohlde
Jayhawk Motorsports
Systems Engineer
All electrical components and wiring harnesses depend on proper circuit functioning, which is the transmission of charged ions by retention of the visible spectral manifestation known as "smoke". Smoke is the thing that makes electrical circuits work. Don't be fooled by scientists and engineers talking about excited electrons and the like. Smoke is the key to all things electrical
Posts: 359 | Location: Lawrence, Kansas | Registered: January 24, 2005Reply With QuoteEdit or Delete MessageReport This Post
I was thinking about a very similar idea Erich. Except that the Bimba cylinder has just one three-way solenoid and I will control the 'exhaust' with flow control. I plan to do a lot of testing and I will post my results here in a couple of weeks if any of you are interested. Thanks for the insight.
Joe Santore
Cooper Union
did you get the bimba cylinder with the integrated solenoid? we went away from those a few years ago because we have more options with external solenoids.
Erich Ohlde
Jayhawk Motorsports
Systems Engineer
we use humphry 310 valves. We have about 500 in stock if you need any
Posts: 21 | Location: alabama | Registered: May 04, 2008Reply With QuoteEdit or Delete MessageReport This Post
We've been running an electro pneumatic system since 2006. We have a single action pneumatic cylinder on the clutch with a 3/2 12V solenoid valve. For the shifts, we have a double action cylinder with two 3/2 12V valves. On the release side of the clutch cylinder is a flow control valve. This allows us to launch electro pneumatically( although, not very cleanly).
In 2007, I worked on a clutch and shift controller based on a microcontroller. It was all time based and worked OK for shifts. As for the clutch, we replaced the 3/2 with a 0-10 bar pressure regulator. Even with the regulator, we couldn't precisely control the clutch position because the force is not very linear. Also, the pressure regulator couldn't handle the electrical noise in our car (mostly clicking relays and ignition coils). So during Michigan, we had to revert back to our 2006 system because the car wouldn't clutch sometimes because the pressure regulator wasn't responding.
This year, we will be attempting a version 2 of the shifter/clutch controller based on closed loop feedback. Basically, a potentiometer will be fixed on both shifter and clutch barrels to measure their position. Then, by actuating a 3/3 valve using a microcontroller, we'll be able to position reliably the clutch or shifter.
At the same time, we will remeasure the required loads and try to optimize our air cylinder packaging.
Good luck with your project!
Julian Choquette
EPM Motorsport
École Polytechnique de Montréal
Electronics director
Posts: 6 | Location: Montréal (Québec) Canada | Registered: September 18, 2006Reply With QuoteEdit or Delete MessageReport This Post
For clutch control my school tried the 3 way valve with a restriced exhaust in the past, but there is a significant time delay issue that no one is mentioning here. When you set the exhaust restriction you are controlling the air release to get a smooth and somewhat slow clutch lever travel over the short distance of travel between the friction point and what little overtravel you can adjust in. The monkey wrench in this concept is the fact that you use more pressure to disengage the clutch than is needed to just hold the clutch open. So when you first deactivate the clutch solenoid to cause the clutch to engage, the clutch lever doesn't start moving until the pressure in the cylinder has gone from the system set pressure to the 'holding' pressure of the clutch cylinder. Once enough air has exhausted from the chamber (through a small restrictor now) the clutch lever starts its travel and the clutch engagement process starts.
This effect was most noticable not when launching, but when downshifting and having to wait on the clutch while driving. We eventually removed this system and continued using the hand clutch for launching the car. A hand clutch on the side of the car can be very light, this was a few years ago and it was a cable clutch on a Honda F3
Dave Cook
If incorporated into an airshifter system you may need two regulators, one for shift and one for the clutch or play around with the clutch cylinder bore size until the system pressure closely matches the 'holding' pressure.
Posts: 32 | Location: Novi, MI | Registered: November 01, 2002Reply With QuoteEdit or Delete MessageReport This Post
I see what you're saying about the time delay, but I am not attaching the piston directly to the clutch pin. The gxr engine comes standard with geometrical clutch actuation through a cable, so I plan to pull the cable to get more "play" with the clutch.
So, I bought a PWM controlled proportional valve and am going to attach it to the exhaust of the solenoids you gave me. With the use of a microcontroller and a linear pot, I'll be able to use a feedback system on the location of the piston and be able to variably adjust the flow electronically each time so that the acceleration of the piston does not exceed a certain value and bogs down the engine.
I plan to test it within the next week, but if I notice a time delay on the clutch when running it on the engine on the dyno then i'll let you know. Did you test the clutch system on an engine on a dyno because I know the clutch acts differently when its cold compared to when its hot and that may have been causing an unexpected time delay?
Joe
I think you are going to find the behavior of this system to be very nonlinear. When you first start venting the cylinder you will see no motion for a time as the pressure drops from the system pressure to the pressure needed to hold the clutch open. Once these pressures cross you will have an increasing rate of motion that will require at rapid change in the pulse width that could be hard to do smoothly.
Its not impossible, but I also remember how many of the Formula 1 teams continued getting this wrong when they did launch control. It will be interesting to see how you do. I'd keep a hand clutch design for launching the car in my back pocket just in case.
Dave
