    FSAE.com Forums    FSAE.com Forums  Hop To Forum Categories  Open FSAE Discussion    Small helmets
With the recent DQ's for head position, and the helmet and padding rules that seem to be getting more attention, has anyone looked into helmets that are smaller?
Also, are helmets for smaller head sizes also smaller on the outside, or do they pop out all of them on the same mold and just compensate with foam on the inside?
Thought I'd as on here before I bust out the tape measure at the local motorcycle store.
Matt Brown
Alum
U. of Oklahoma
http://sae.ou.edu
Posts: 158 | Location: Valencia, CA | Registered: April 19, 2005Reply With QuoteEdit or Delete MessageReport This Post
What keeps you away from building rule compliant cars? I do not want to offend you, but is it really necessary to build cars that are so close to the rules minimum that you have to be afraid to pass scrutineering or be disqualified?
Head of Electronics '06 '07 '08
Lions Racing Team Braunschweig
"Reality must take precedence over PR, for Nature cannot be fooled." Richard Feynman, Investigator of the Space Shuttle Challenger disaster
- Three nations have not officially adopted the International Metric System of Units as their primary or sole system of measurement: Liberia, Myanmar and the United States.
- 1 Inch was defined to be the thumb width of Heinrich, I., King of England.
- Later 1 Inch was redefined to be the length of 3 barleycorns by Eduard, II., King of England.
- 0°F were defined by Fahrenheit in the harsh winter of 1708/1709 as he thought that it is impossible to become colder than this
- 100°F were defined by Fahrenheit to be the normal temperature of the human body. Obviously he had fever, when measuring his own body temperature to define his scale.
Posts: 96 | Location: Braunschweig, Germany | Registered: October 31, 2007Reply With QuoteEdit or Delete MessageReport This Post
1. Racing demands to be right on the edge of rules minimums. Most notable are weight requirements, and as we can all relate to, ground clearance.
2. Yes Matt. I know that my helmet is bigger in outer diameter than Bobby's, and that our smallest team helmet. The other half is that the bigger helmet is racetrack rated, and the others are motorcycle rated. It is also important that the difference in this size is negligible. Put another way, the difference in size is not on the top of the head, where the measurements count.
David Collins
"By definition, a hard driver is one possessing little, if any, brains."
Posts: 39 | Location: Norman, OK | Registered: November 02, 2007Reply With QuoteEdit or Delete MessageReport This Post
If you stay safely within the bounds of the rules and never try to push limits you're not going to beat anyone.
I believe we are responsible for at least one published rule clarification for pushing the envelope. Our most recent car had SEVERAL things that we thought "That's really close, I sure hope it passes"
It's our job to build TO the rules, not under them. It's the scrutineers job to catch if we break them.
Besides, we just have fat heads.
Posts: 360 | Location: OK | Registered: September 24, 2006Reply With QuoteEdit or Delete MessageReport This Post
In my opinion passing scrutineering with no problems gains you more points than building a car to or over the edge of the rules. Especially with the events growing bigger and bigger and the scrutineering taking longer.
mok
Picture of mok
As Tobias said, in my opinion this is definitely not true for Formula SAE. You can build a perfectly rules compliant car and still beat all "not so rules compliant" cars.
My experience is, that most points on a FSAE car that are possibly in conflict with the rules, are simply there because the team members haven't paid enough attention to the rules and NOT because they are knowingly pushing the limits.
But: It is perfectly fine to look for example for smaller helmets if you got a tall driver. If you've got small drivers, than Percy is going to be the tallest anyway - and you can't change Percy's helemt size ;-)
Michael Kissling
Rennteam Uni Stuttgart
Stuttgart, Germany
Posts: 20 | Location: Stuttgart | Registered: November 20, 2005Reply With QuoteEdit or Delete MessageReport This Post
BTW, we met Mr Percy personally when he wanted to take a seat in our car at Silverstone. He used an L size helmet, I think our smallest one.
Wink
Posts: 25 | Location: Switzerland | Registered: January 16, 2008Reply With QuoteEdit or Delete MessageReport This Post
That may be true for performance-sensitive areas, but it's ridiculous to apply it to every rule.
In this case, adding the 1 lb or less to make your car meet the rules is all it takes. Just do it; that is not what is going to lose you the competition.
In motorsport there are minimum weight rules, however it is not uncommon to have a car 5 or 10 lb over the minimum weight. This is a safety factor to avoid being disqualified. It's not worth it to push areas that can ruin your entire event (yes even in 'racing').
Auburn FSAE Alum 00-04
Well put by all. A few last comments to the matter:
1. The original question of the post has been answered, without much contention or a link to Google. Applause to all.
2. We met a real-life Percy in California. I've accepted that it was proof that in beautiful Southern California, even Mr Royce will have some fun with scaring the bejesus out of the student teams.
3. Charlie, I completely agree with your safety factor point. The number of times I've seen a driver disqualified for not meeting min weight is absurd. That should never happen. On the other hand, it took three pounds of tubing to make our 2008 car rules compliant with the helmet clearances.
David Collins
I wasn't suggesting that teams should push the rules. Building close to the limit of the rules and buying a small helmet are two different things. If you design for a 2.25" clearance with a small helmet, and you would have designed for a 2.25" clearance with a large helmet, you're in the same boat at tech inspection. I was actually wondering if any teams had designed for adequate clearance and then looked for smaller helmets as an added buffer.
For the sake of the argument that has arisen...
If you have a driver that is taller than perci: a 0.1lb decrease in weight for designing around a smaller helmet, while maintaining the same adequate clearances, is an excellent design decision in my opinion. Especially since it is something you have to design around anyways.
In any case, make sure your CAD helmet is the same size as the helmet you're going to race with, lest you spend your labor day weekend cutting and re-welding.
Matt Brown
Alum
U. of Oklahoma
http://sae.ou.edu
Picture of Yellow Ranger
But if you can't make the rules fit Percy, there's a likely possiblity that you won't be able to fit a 'normal' sized helmet...
BTW Matt, no luck on that shock- how's the bike coming?
1.2 Vehicle Design Objectives:
“The intended sales market is the nonprofessional weekend autocross racer.”
“The car must be low in cost, easy to maintain, and reliable.”
Posts: 39 | Location: Okieville | Registered: October 25, 2006Reply With QuoteEdit or Delete MessageReport This Post
Show me one, and I'll retract the statement.
Our current car.
This message has been edited. Last edited by: TMichaels,
Which competition did you win? I'm not up on the European ones.
And are you defining a "perfectly rules compliant car" as one that passes tech without modification?
We came in second at the FSG this year. If that is not enough, I would refer to Stuttgarts car. They won the FS UK this year.
I define a "perfectly rules compliant car" as a car that meets all rules including the intentions and clarifications of the rules.
So, since tech inspection is the sole evaluation that establishes meeting this criteria, all cars that passed tech inspection are, as per the rules, rules compliant.
Picture of Drew Price
First:
The original original question of whether or not small helmets had the same outside dimensions as large ones is one I was hoping someone knew the answere to, and has not been answered yet. I would be willing to bet that some are smaller on the outside than others, but would probably require calling up MFG's or going to look at a motorcycle shop to check. Our big motorcycle dealer even carries some SA2005 rated helmets, along with the slurry of DOT ones, you I could probably get legit comparisons.
Not sure about your drivers but we had two very tall dudes drive the car this year - both around 6'3" - 6'4" - and one needed a large helmet, the other a small, so I think that is a reasonable valid observations. Some tall guys have small heads. Some short guys have big heads. Whether or not it's the same size head as Mr. Percy (a well documented big head) may or may not be important.
Second:
Certainly don't want to get caught too much into this, since it's waaaay off topic now, but we certainly didn't have anywhere NEAR everything on the tech sheet scrutinized by the inspectors during tech at Michigan this year.
I have heard the FS competitions the process is much more stringent, but there is simply not time to check compliance of every single rule in the rule book in the ~3-4 hour average time most teams spend in tech.
That changes the def a little bit.
Of course, we observed from the process that the adage that if you can gain an technical advantage by stretching a rule that either won't be checked, or is difficult to verify is part of the game. You have to weigh the tradeoffs.
We feel that since this is an educational experience, we are willing to sacrifice a percent here, and half a percent there to make sure that we get through tech the first time (which we did) and have extra time to be doing more useful things at comp, we will sacrifice the one percent.
Besides, it seems to me that impressing the design and presentation judges and finding a driver who know's what they're doing is a better way to ensure you will maximize your chances to get the points than it is to risk not fitting Mr. Percy by getting your CG 0.1" lower. But obviously the design judges like that sort of thing, so we're back to the beginning.
As always, my $0.02 (0.014 €).
Maybe I will change my sig line to Vonnegut's "And so it goes..."
Best,
Drew
Posts: 211 | Location: Evanston, IL | Registered: December 03, 2006Reply With QuoteEdit or Delete MessageReport This Post
The disqualifications after or during the endurance at Formula SAE at MIS show that this may not be correct.
As tech inspection is not a singular event, and occurs continually throughout the competition, (as per the rules) it follows that if you meet them to the committee's standard throughout the entire competition, you fulfill the rules, as declared by the rules.
To say that you have a to-the-letter, to-the-intent rule-meeting car is false. You have a to-the-rules-committee approved car. Whether or not you intentionally met every rule, you have no guarantee you met any rules other than the ones the committee checked.
I am confident in asserting that there is something on your vehicle that, if inspected closely enough, could be seen to violate the intent of a rule. It might be as minor as not meeting the "three exposed threads" rule on bolts.
In an extreme example, do you machine your restrictor 2mm undersize "just to be safe?" Not likely. While it seems that example would (correctly) have a greater performance impact than 2 inches of rollbar tubing, it has been learned from experience that in FSAE, every little bit helps. If you save an average of 50 grams on 50 components, thats 6 pounds. If you can average higher than that, so much the better.
I agree that it may make tech less stressful to provide margins of safety on highly scrutinized items, but if you don't try to push those boundaries, you might never gain those .001 seconds. That's all it takes to win.
JVC
Picture of JVC
I agree, it is a competition so it is not more than logical you try to get the most out of your car by interpreting the rules as much to your advantage as you can. However, there is one thing that cannot be compromised on a FSAE car, and that is safety (both Braunschweig and Muenchen had a crash this year, and our car flipped over last year).
This is simply not true. To add another example to the list of fully rule compliant cars that beat the rest, it would be the Delft car. We came second at FS UK this year and we won FSG. And that with a car with a main-hoop line that easily accommodates drivers up to 6'4", and an impact structure that, despite the low sides, is way beyond the impact structure required by the rules, not to mention the protection against A-arm penetration by a carbon monocoque.
So instead of trying to dodge the rules running the risk of being, in the worst case, disqualified, be inventive incorporating the rules in your design instead. All you need to do is to think outside the box.
DUT05 Chassis & Suspension Engineer Class 3
DUT06 FSUK Trip Organiser
DUT08 Chassis & Powertrain Engineer Class 1
DUTch Open Organiser
DUT09 Chassis Engineer Class 1
Delft University of Technology Formula Student Racing Team
Sleep is a symptom of caffeine deprivation.
Without good coffee life would be a mistake.
Posts: 5 | Location: Delft, The Netherlands | Registered: September 03, 2008Reply With QuoteEdit or Delete MessageReport This Post
