    FSAE.com Forums    FSAE.com Forums  Hop To Forum Categories  Open FSAE Discussion    Zero Roll Stiffness
Picture of Schumi_Jr
The Dallara F3 cars have been running a front monoshock for a while now. They achieve roll stiffness by using a couple of bellville washers. I'm not sure how successful the design is but Dallara totally dominates F3.
If you don't have any damping in roll then a) your car will oscillate undamped in roll
and b) you lose a significant element of transient u/s o/s tuning.
Aaron Johnston
University of Waterloo FSAE
www.eng.uwaterloo.ca/~fsae
Posts: 101 | Location: Charlotte, NC | Registered: September 13, 2002Reply With QuoteEdit or Delete MessageReport This Post
A steering damper from a motorbike could be used (in conjunction with some sort of linkage for adjustability) to do the job for the roll damping...they still use pressurised nitrogen to reduce oil cavitation etc, but since the shaft is a 'through' type, they dont have the preload normally associated with regular shockys.
Then both the roll and bump systems would be fully independent of each other, yet still fulfill their roles completely..
just a thought.
Sam.
Posts: 24 | Location: Bris,QLD,Aust | Registered: November 09, 2002Reply With QuoteEdit or Delete MessageReport This Post
Dammit! Stop wasting time thinking outside the box, and just do a conventional setup like everyone else ! ! Eek ! Big Grin
I don't see enough people using Gas-Struts - as in the thing holding up your bonnet or boot/tailgate. Cheap and readily available, it's a spring AND a damper in one ! ! I don't quite understand why you'd chase a lower roll resistance: I'd be chasing Zero roll with maximum wheel independance - like the de-coupling Anti-Roll bars mentioned before. I've seen these done with hydraulic rotary coupling IN the A.R.B, and hydraulic A.R.B. MOUNTS - coupled to another hydraulic mount on the car's opposite corner.
BMW also do Active de-coupling of roll bars in their "Dynamic pack" for the 5/6 series Luxo-barges.
Hell - just blow the entire S.A.E. Budget on doing fully active suspension ! ! !
Posts: 2 | Location: Melbourne | Registered: October 27, 2005Reply With QuoteEdit or Delete MessageReport This Post
Picture of Garlic
OK... but you can't design a suspension with a half dozen random thoughts. Wink
mmmm..... Garlic.
Posts: 268 | Location: Up Over3 | Registered: October 28, 2004Reply With QuoteEdit or Delete MessageReport This Post
Picture of jdstuff
Will,
Just a little more background info, if you would like to know. As both you and Clausen mentioned, FVee's utilized "zero-roll" rear suspension...which means that almost no roll stiffness is provided by the rear suspension. The reasoning behind this is most likely a solution to an altogether different problem: the differential.
FVee's are open differential cars, which as you know can exhibit noticeable inner wheelspin during corner exit on slow/med speed corners. By allowing the front suspension to provide nearly all of the roll resistance, the rear inner wheel will always remain loaded by at least the unsprung weight at that corner. This might not be much weight, but it may be enough for an underpowered car (like a FVee) to prevent open differentail wheelspin.
Anyway, just my $.02......but I'm just a drivetrain guy, so don't take my word as gospel! Hope that provides some more insight.
Jason Stuffel
- C&D Zodiac
-Zips Racing Alum 03-06
Posts: 104 | Location: Vandenberg AFB, CA | Registered: April 05, 2004Reply With QuoteEdit or Delete MessageReport This Post
Picture of Erich Ohlde
We ran a front monoshock on our '05 car. Works great, don't have roll dampening yet but the car has incredible turn-in and handles slaloms extremely well. I'm currently working on a way to include roll dampening. Hopefully the car will handle even better.
Erich Ohlde
Jayhawk Motorsports
Systems Engineer
All electrical components and wiring harnesses depend on proper circuit functioning, which is the transmission of charged ions by retention of the visible spectral manifestation known as "smoke". Smoke is the thing that makes electrical circuits work. Don't be fooled by scientists and engineers talking about excited electrons and the like. Smoke is the key to all things electrical
Posts: 359 | Location: Lawrence, Kansas | Registered: January 24, 2005Reply With QuoteEdit or Delete MessageReport This Post
Think about running the front A.R.B. damping similar to that supplied by the regular dampers in the rear end. Otherwise you'll get a massive imbalance in effective roll resistance under dynamic loads between front and rear ends. i.e. when you turn-in. Has anyone ever tried running a monoshock, with active roll control? Think Williams FW14B, which can be seen here LEANING IN to a corner!
I personally would run a conventional twin-shock/spring system, with no A.R.B. to interfere with wheel independance. To negate body roll, I'd mount the inboard ends of the springs&shocks on a common shaft, which can be moved via worm drive or a threaded shaft.
Mmmmm.. . . Anchovies . . .
Z
Jason,
Re: Formula Vee. These have, as a result of using the Beetle suspension, a ground level "roll-centre" at the front, and an ~axle-height RC at the rear (approx at the centre of the diff). If they had conventional springing at both ends then they would have way too much lateral-load-transfer at the rear, and hence be prone to oversteer in corners. This is because LLT = elastic-anti-roll (from the springs & ARBs) + viscous-anti-roll (from the dampers) + kinematic-anti-roll (from the slope of the line from wheelprint to RC). With the "zero-roll-stiffness" arrangement at the rear, their front/rear LLT's are about equal - all front LLT comes from the springs & dampers, all rear LLT comes from the high RC - hence reasonable handling.
Erich,
The monoshock Dallaras don't have front roll damping because it works better that way! I posted on this in "Anyone else run a Monoshock?" thread.
Z
Posts: 334 | Location: Australia | Registered: March 11, 2005Reply With QuoteEdit or Delete MessageReport This Post
