    FSAE.com Forums    FSAE.com Forums  Hop To Forum Categories  Open FSAE Discussion    Floating brake rotors
Hello
I'm projecting the brakes for a Formula FSAE car and we wanted to use floating discs, but it's hard to find floating discs with 220mm diameter.
Can anyone tell me where did you get your brake discs?
And what are the problems in buying a normal disc, and cutting the inside of the rotor to adapt them to floating?
Thank you,
Luís Monteiro.
This message has been edited. Last edited by: Luís Monteiro,
Posts: 2 | Location: Lisbon | Registered: February 24, 2010Reply With QuoteReport This Post
you get them from the same place as everything else: stock material
UConn Racing
uconnracing.com
Posts: 15 | Registered: December 01, 2009Reply With QuoteReport This Post
In India at least 220 mm rotors are really on almost all motorcycles available. Maybe you could check out the motorcycles available in your market.
I've always had a tough time having 220mm disks inside 13"rims. Make sure you have place to squeeze the calliper between the rim and disk.
Mahek Mody
IIT Bombay Racing
Vehicle Dynamics FSAE 08; FS 09
Posts: 82 | Location: Mumbai India/ Swindon UK | Registered: August 28, 2008Reply With QuoteReport This Post
Lasercutting a steel plate always works.
Posts: 45 | Location: Montreal | Registered: June 24, 2008Reply With QuoteReport This Post
Not if you want flat rotors.
2006 QUT Motorsport - Manufacturing Manager
2007 QUT Motorsport - Controversy Raiser
2008 University of Waterloo Formula Motorsports - Exchange Student / Electrical Team Manager
2009 The University of Adelaide Motorsport Team - Consultant
2010 The University of Adelaide Motorsport Team - Project Manager
Posts: 112 | Location: Adelaide | Registered: April 29, 2006Reply With QuoteReport This Post
Perhaps you need a better laser-cutter! Ours have always been flat.
Iowa State University
http://www.sae.stuorg.iastate.edu/?page_id=93
U.S. Army Field Artillery Platoon Leader, Afghanistan '10-'11
Technical Director Fall '07, '08-'09, '09-'10
Suspension Team Leader '06-'07
Random Grunt '02-'06
Posts: 453 | Location: Boone, IA | Registered: October 22, 2005Reply With QuoteReport This Post
Beg to differ. Have done it in our teams for tha last few years and has always worked. Thick plate though(1/4"i fmymemory serves me well)
Posts: 2 | Location: École Polytechnique de Montréal | Registered: January 19, 2010Reply With QuoteReport This Post
Picture of Pi­co
Originally posted by Luís Monteiro:
Hello
And what are the problems in buying a normal disc, and cutting the inside of the hub to adapt them to floating?
Thank you,
Luís Monteiro.
Usually the floating discs you would find on the market are for front motorbike brakes. They dont sell the disc but only the whole assembly (rotor and mounting plate). There is an article by Brembo about floating discs if you could find it. Best quick option is to modify a normal disc.
Philippe
Technical Director 07-10
McGill Racing Team
"Everything should be made as simple as possible, but not simpler." A. Einstein
Posts: 25 | Registered: September 23, 2008Reply With QuoteReport This Post
We always used Marting Custom Products (http://www.mcpbrakes.com/). Sent them a CAD drawing of our brake design. They would laser cut them and then Blanchard grind them to our desired thickness. Never had any problems.
Posts: 58 | Location: NC | Registered: November 22, 2004Reply With QuoteReport This Post
Originally posted by Pi­co:
Hello
Thank you,
Luís Monteiro.
Usually the floating discs you would find on the market are for front motorbike brakes. They don't sell the disc but only the whole assembly (rotor and mounting plate). There is an article by Brembo about floating discs if you could find it. Best quick option is to modify a normal disc.
When you say Brembo has an article on modify a normal disc to floating do you mean cut the rotors? Because that was the kind of adaptation I was thinking of.
I've tried to contact several motorcycle brake manufacturers, but most of them only have discs models displayed by motorcycle models. The brand I found that displayed a catalogue with dimensions of the disc models was Galfer, and they aren't answering to my emails...
Thank you for your reply,
Luís Monteiro.
Thicker plate and blanchard grinding to size works well....
Finished @ UofT Racing
2003-2007
www.fsae.utoronto.ca
Posts: 292 | Registered: July 09, 2003Reply With QuoteReport This Post
Iowa Laser can cut them 1/8" without any warping that I can measure.
220mm disks are easy to fit inside a 13" rim - standard Formula Ford, Formula Continental, and F1000 disks are 254mm, and 263 can be fitted, depending on the caliper used.
220mm disks inside 10 inch rims could be a hassle, however.
For decent, low-cost rotors, stick with Ductile cast iron. Grey CI will work fine if you are not heating them too much (thermal cracking resistance of grey CI is not as good as for Ductile). The vast majority of cars come equipped with grey CI rotors, so finding an aftermarket rotor shouldn't be very hard, unless you are using a too-small inside diameter (anything under 5 to 5.5 inches, most likely).
If you use modified street car rotors, you will want to have them stress relieved before you cut them to the final thickness - cut them to about 1.5mm thicker then final, then get the sterss relieving done. Make sure that the heatreater lays them flat on a FLAT surface or they will relax to conform to the uneven surface once at temperature.
I can supply rotor blanks in Ductile if you need (have done so for lots of teams over the years) E-mail me at rpare@prodigy.net if you don't have any luck elsewhere.
Posts: 39 | Location: Indianapolis, IN | Registered: May 02, 2005Reply With QuoteReport This Post
Picture of Pi­co
Hello
Thank you,
Luís Monteiro.
Luís Monteiro.
It was an article about the floating mechanism.
Everything warps without exception. you could mill them (cnc?) out a thick plate then mill them down to thickness if you cant find an aftermarket equivalent.
Philippe
McGill Racing Team
Mill and grind. Or waterjet and grind. Or Lasercut and grind. Take your pick.
University of Oklahoma Alum '09
Posts: 641 | Location: OK | Registered: September 24, 2006Reply With QuoteReport This Post
hi, this is my floating disc setup..
the hub is milled to accept the disc directly..
the disc is held by the hub on one side and a simple plate on the outside (held on by the wheel)
the disc is Alfa romeo alfasud unit, which is nice and flat 10m thick 257 mm diam, milled into final dimension (245 diam..)
this is the original brembo disc..
http://www.bremboaftermarket.c...?ModelIDMaster=11733
This message has been edited. Last edited by: Vlado,
Posts: 6 | Location: Zagreb, Croatia | Registered: March 20, 2007Reply With QuoteReport This Post
Originally posted by Vlado:
[QUOTE] 10m thick 257 mm diam, milled into final dimension (245 diam..)
I think you mean 10mm which is still plenty thick, last year our fronts were less than half that thick, and the rears thinner yet. But just because we did that doesn't mean it's "right".
Ryerson Formula SAE
Toronto, Canada
Posts: 56 | Location: Toronto, Canada | Registered: September 24, 2008Reply With QuoteReport This Post
The disk does seem rather large.
Are you using 13" rims? How did you manage to package this inside them? What is the inside well diameter of you wheel where the disk is placed?
I am asking because I have always struggled to fit 220mm diameter disks in our 13" rims. I feel as if I am missing a trick.
Mahek Mody
IIT Bombay Racing
Team Captain
Ryerson Formula SAE
yes, 10mm... of course.. Smile
but I am not building an FSAE car, but something with 180 HP, so want a bit more "disc"
I am using 13inch Compomotive CXR wheels, and with wilwood 4 pot calipers I can get a 255 mm disc inside, with no problems.
However, I have decided to push the discs outboard as much as I can, to ger a lower KPI, and had to reduce the disc to 245mm.
if you ask compomotive, they will send you a cross section of the wheel, with all the dimensions..
Picture of DART-CG
Laser- or watercutting a sheet metal with a milling procedure afterwards always worked very good.
In 2008 we had a brake disc failure on the rear axle 24h before the Baltic Open event.
With no time to grind new ones down anymore we lasered a substitute from a sheet metal with the desired 3mm thickness. Afterwards we bended them by hand (!!!) until no distortion was measureable any more. Russian style but it worked without any problems
DART Racing e.V., Darmstadt
Alumni
Technical Director Suspension & Brakes 2005-2007
Brake System Developer 2005 - 2008
CFRP Rim Specialist 2008
Test Team and Driver 2005-2009
Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere.
Colin Chapman
Posts: 102 | Location: Darmstadt | Registered: December 16, 2007Reply With QuoteReport This Post
  Powered by Social Strata Page 1 2
