Our team run with a honda cb 450 engine. We are installing a fuel injection system. Then we found a problem. Instead of an alternator, this engine has a magnet. We intend to atach the trigger wheel with the magnet. The problem is: will the magnetic field of the magnet interfere on the sensor reading of the trigger wheel, as this sensor is an indutive one?
To solve this problem, one solution that we thought is to atach the trigger wheel with the magnet with an axle and than separete them a bit to minimize the magnect effect of the magnet. But we didnt test this yet.
could your sensor read the trigger wheel when you had this similar situation?
There are many ways to solve this; what you wrote is one idea.
My understanding of where the team is going to solve this issue is limited since I graduated. That being said, we have a unique option that should work well for us due to the particulars of the Suzuki engine.
I guess it also depends on whether you are happy running wasted fuel/spark or whether you want semi/full sequential.
