    FSAE.com Forums    FSAE.com Forums  Hop To Forum Categories  Open FSAE Discussion    WR 450 Gear Ratios
Does anyone know the individual gear ratios inside the transmission for the Yamaha WR 450, both the quad versions and the bike versions? Also primary and secondary gear reductions if any and what their ratios they are?
jason
Posts: 31 | Location: SLO, CA | Registered: July 07, 2004Reply With QuoteEdit or Delete MessageReport This Post
Will advise when we get back to Melbourne next week.
Cheers
Geoff Pearson
RMIT FSAE 03-06
Design it. Build it. Break it.
Posts: 345 | Location: Melbourne Australia | Registered: June 17, 2003Reply With QuoteEdit or Delete MessageReport This Post
ben
Picture of ben
This seems to have the info required:
http://yz450f.yme.com/pages/default.htm
Ben
Senior Design Engineer (American Le Mans Series) - Dunlop Motorsport
Alumnus of University of Birmingham
www.ubracing.co.uk and Formula Student Design Judge
Posts: 632 | Location: Birmingham, England | Registered: September 15, 2002Reply With QuoteEdit or Delete MessageReport This Post
Here's the spec's from that site.
Type
Liquid cooled, 4-stroke, single cylinder, DOHC 5 valves
Displacement 449 cm3
Bore and Stroke 95.0 x 63.4 mm
Compression ratio 12.5:1
Max. Power N.A.
Max. Torque N.A.
Lubrication Dry sump
Fuel supply Carburettor (FCR39H)
Clutch type Wet, multiple disc
Ignition C.D.I.
Starting system Kick
Transmission Constant mesh, 4 speed
Final transmission Chain
Gear ratio 1 1.929
Gear ratio 2 1.563
Gear ratio 3 1.278
Gear ratio 4 1.05
Primary reduction ratio 2.818
Secundary reduction ratio 3.357
Um...there's one really important thing that this engine seems to be lacking. Anybody?
Maybe the quad version has it?
UNM FSAE 2003 to 2005
Posts: 339 | Location: Albuquerque, NM, USA | Registered: June 06, 2003Reply With QuoteEdit or Delete MessageReport This Post
If you're talking about an electric starter, the wr450f engine has it, but the yz450f does not. The wr450f also has a 5th gear.
Posts: 3 | Location: Boulder, CO | Registered: December 02, 2003Reply With QuoteEdit or Delete MessageReport This Post
The WR electric start bolts onto the YZ engine, from what I can see, but you need the WR rotor cover casing and a few gears and stuff - could be quite expensive.
The WR450 is a five speed, and I think the YFZ450 ATV is as well, but from the parts listings I have they are different gear ratios. I'll check all this when I get home, probably Monday next week.
Cheers all
Geoff Pearson
RMIT FSAE 03-06
Anyone got a dyno chart for it? I looked around on the net a bit and couldn't find one.
-Mike Waggoner
The older I get, the faster/harder working I was...
Posts: 253 | Location: Seattle, WA | Registered: September 19, 2002Reply With QuoteEdit or Delete MessageReport This Post
Picture of Denny Trimble
Here's a "half throttle" run off this website:
http://www.cyclecost.com/shopping/powernow/power_now_dyno.htm
You could scale it up to whatever you expect the peak power to be. YMMV Smile
Also, it's a CRF 450, I don't have a clue how that compares to the WR450.
Wasn't somebody getting ~70 hp out one of these engines...seems like a great hp/weight ratio!
How much do these weigh? I think the F4i weighs in at 120lbs, can't remember if this was wet or dry. Anybody got a torque curve to share?
Also, Is the WR450 a dirt bike?
ben
Picture of ben
I'm assuming that if the YZ450F doesn't have an electric starter, the CDI ignition is magneto driven rather than running off the battery?
Ben
thanks for the help.
jason
Picture of Rev Hard
We urgently need CAD model and manual of Yamaha WR 450.
If you can help please mail me at dcemech89@gmail.com
Posts: 8 | Registered: August 26, 2008Reply With QuoteEdit or Delete MessageReport This Post
