FSAE.com Forums
FSAE.com Forums
Open FSAE Discussion
Things that you should have in your workshop <for new teams>|
Here is the compiled list:
Hand Tools/Safety equipments/furniture Priority One (no matter what, you must have): First Aid Kit Fire Extinguisher Safety Googles Welding safety equipment (gloves, helmet, jacket) One complete drill bit index One complete screwdriver set One complete allen keys (metric AND imperial) set, extras for 3/16" One complete wrench (metric AND imperial) set, double up on 7/16", 1/2", and 9/16" One complete set of socket wrenches (or two, one for small things and one for big things) Ruber mallet Ball peen Hammer A good Hacksaw Basic electrical crimper and soldering iron A multimeter Measuring calipers (vernier, dial, digital, up to you) Tape measure A good ruler set (steel rulers) A compass A good protractor A height gage A box of Sharpies (silver for tubes) Extension cord reels Air hose reels Heavy duty grit soap (i guess is pink coloured and smells like orange) Rags (lots of them) Broom Trash Cans Degreaser for floor A large table, preferably: Level Flat Steel/Cast Iron/Metal Stiff T-Slots or Threaded Holes for fixturing (preferably with associated hardware) Sawhorses A set of files wire brush for cleaning files A working bolted down vise with some soft jaw inserts (can be strips of wood even) Priority Two (might wait a little but you will need before/during test phase): Jb weld (several packs) Tin snips Rivet Gun Torque Wrench - 3/8 drive 25-250 in*ln (don't know the ranges, but as this was the only value listed...) a good tire pressure gauge Priority Three (life will be easier with, but not impossible without): One set of Ratcheting Wrench Dead blow hammer minifridge (an esky will do too) microwave phone Power Tools / electrical devices / related Priority One (no matter what, you must have): Welding equipment (TIG, MIG, Arc Welder. Most desirable to less desirable order) Bench Grinder Tube notcher and a hole saw kit Air compressor (if possible one that can handle two tools without loosing pressure) Air tool set (die grinder, impact gun) Hand drill Chop saw Priority Two (buy if you have money to spare, not having at hand will slow you down a bit, you can use sponsor's/university's one): Drill Press Tube bender and appropriate die (it can be priority one, depending on the team/uni) Belt sander Abrasive cutoff air tool Plasma cutter Priority Three (Better use sponsors/universtity's one, unless you are LOADED): Mill Lathe Autoclave CNC machine I guess I put everything here, if I missed any priority/item, please let me know =) Dynamics & Electronics Team Captain KAIST FSAE Team 2008-9 |
These are consumables, but possibly the most useful things you will get. Quality zipties, duct tape and fabric tape
Also for the crimper pleeeease put ratcheting in front of it. It's not much more expensive than a 'basic' crimper, but the job it does is worlds apart. I'd also be tempted to say that the fridge and microwave could be placed into priority one. Having those two items in the workshop is really handy. We also have cans of soft drink in ours and people buy them for a dollar and the money raised is used for general shits and giggles items. |
Make friends with the peoeple responsible for the automotiveshop/composites lab/machine shop. You need these people on your side. In time as your team gains respect, access to these things should become easier.
Life is damn interesting |
Damn how did I leave ZIP TIES off my list. Those are F essential.
I only see now where you're posting from. Not sure how much English hardware you'll use. For us, we used either AN or SHCS hardware for just about everything. Since suspension fasteners tend to be 1/4", 5/16", or 3/8" (though we've migrated toward all 1/4") having double 7/16, 1/2 and 9/16 wrenches is a good idea. Likewise if you have a heap of 1/4" SHCS on your car, since 3/16" is the allen key for it they tend to get misplaced easily. If you're going to use all metric hardware.. there's some savings! If you're going to get JB Weld... well.. at least it isn't JB Kwik. But you might as well just buy some "legit" 3M epoxies. They have one for every application. Composite bonding, metal-on-metal, probably high temp stuff... RTV would also be an essential.. red for high temp, blue for extra oily surfaces. Loctite.. And of course, Race Tape and Speed Tape. They are different, so do not get them confused. This is race tape This is speed tape Race tape is good for all motorsport applications. Speed tape.. I forget why we originally started using it.. perhaps to seal radiator stuff.. but it makes your car look fast. Guaranteed to add 3.8hp. In all seriousness aluminized tape works pretty well, but McMaster sells stainless steel tape which looks pretty BA. |
I can't believe I also forgot zip ties.
Buy them in bulk; 10,000 is not too many. |
The big list left off oxy-acetylene welding torches/bottles/etc. Ain't no race shop in the world without a flame wrench, plus you can actually weld with them too...life before Tig, how did they get along?
Here are the two tools that I loan out at the track most often, I am amazed that people don't have these. Portable air compressor, and a long reach Allen key socket set. Major convenience tools. Brian |
1/2 in square drive torque wrench if it has not already been listed above.
An attitude of leaving tools , work areas clean and safe and treating tools with the respect they are due. They are not your personal property to be loaned out to friends and family as you feel the need. Suitable in/out arrangement to keep track of the items in question. A pegboard or something similar is usually sufficient. Speaking of which... I recall seeing one "mechanic" fired on the spot when the threw a torque wrench over the hood of a car onto the work bench because he was too damn lazy to walk around and put it back on the pegboard where it came from. Along with a set of fire extinguishers a purpose built cupboard for holding thinners , acetone and other potential fire starters and combustibles. Some sort of routine service and safety schedule for things like the air compressor , welder , grinders and anything likely to do damage to the person using it. Same for tools needing calibration checks. Some sort of office for keeping records , drawings , books etc out of the workshop environment. Decent lighting and ventilation and a lock on the access door ! Cheers , Pete. |
Most important thing in our office: Each of our captains has their own set full of notes and highliting and such, but the office / tool box / book shelf should have a set that stays in the shop. Best, Drew Northwestern Formula Racing Head Engineer, Frame/Suspension ----------------------------------------------------------------------------- "The Devil isn't in the details, it's the details that make the design." It has been proposed that we name the car after my girlfriend, so that I can spend all my time with her. [http://www.northwesternformularacing.com/]Northwestern Formula Racing[/URL] |
Gear wrenches are that good? I'd seen 'em.. look cool.. thought about buyin a full set but didn't know if it was worth it.
And +1 on the gas lenses. You might think theyre big and awkward, and how the hell could you use em for getting in tight places.. but they seriously rock for gas coverage. You can run a LOT of stick out with the tungsten and get into really tight areas. On a similar note.. for TIG welding rod I highly reccomend really small gauge wire. 0.045" 70S-2 (or your favorite) and 0.032" stainless wire (of your choice). Makes for really nice control on thin stuff. For aluminum, thicker tends to be better. I didn't use anything less than 3/32 or 1/8" rod. Oh and a pedestal wire wheel rocks as well for cleaning the ends of 4130 tubes before you weld em. Wire wheel the crap off, and wipe with alcohol or acetone. Clean metal, and tight fitup.. will make for hours less welding time at 3am, and less time bitching out your suspension guy for leaving 1/4" to 3/8" gaps to weld. Autodarkening hood.. also a real good investment.. you can get by without one, but it makes life a lot easier when you're in some really awkward position on the ground, welding the frame and trying to control the pedal with your knee, elbow, or ass. |
I really like them. The packaging advertises the swing between pawls on the ratchet, I think it's 6* for the smaller ones, and 7* for the larger ones, so especially in confined spaces you can make sure that you can actually ratchet fasterners in and out with limited space to spin the wrench. I prefer the non-reversible ones, because the box end is thinner, improving access, and there is no flange on the rotating portion of the box end to retain a nut like some of the reversible ones have so you can slide it down a long stud to get it on the bottom jam nut for example, handy if it has started to round. The open ends are on the thin side too, compared to a standard Craftsman for example - somewhere in between a regular wrench and a thin or ignition wrench. They also come with a lifetime warranty, and I have had my metric set for coming up on 6 years, and have never had to get a wrench replaced, and I have bashed on them with hammers and the crescent wrenches that I don't have to get stuck / rusted / stubborn bolts off my old Saab 900's. They're quality. Completely agree on the auto-darkening hood. One of the welding info sites I came across has a review of a $55 auto-darkening hood which he says actualy works really nice, and is even somewhat adjustable, HERE . Best, Drew Northwestern Formula Racing Head Engineer, Frame/Suspension ----------------------------------------------------------------------------- "The Devil isn't in the details, it's the details that make the design." It has been proposed that we name the car after my girlfriend, so that I can spend all my time with her. [http://www.northwesternformularacing.com/]Northwestern Formula Racing[/URL] |
Nice. Might have to pick some up.
Back on the subject of stuff to have in the shop, how bout this one? First aid kit that's stocked and in plain sight - So you don't have to use makeshift bandages out of paper towels, shop rags, electrical tape, and/or zip ties. |
Make sure the first aid kid is stocked with superglue, good for bonding cuts =P
And last but certainly not least, a nearby pub Kind Regards, Chris Lane Design Team Leader - ECR 2008 http://engineering.ecu.edu.au/ecr ------------------------------------------------------ "Race Tape is like 'The Force'. It has a dark side, a light side, and it holds the Universe together" |
You can build an SAE car almost entirely with an angle grinder and epoxy.
2008-2009 Chief Engineer Columbia University FSAE " Auto racing, bull fighting, and mountain climbing are the only real sports ... all others are games." - Earnest Hemingway |
A few more along the lines of 'for the person' things:
Aside: In high school I was heavy into classical music performance, and was nearly a music major. There is a story about the Principal Oboist and the Principal Clarinetist of the Chicago Symphony (I think). The clarinetist and oboist often sit next to one another in orchestral settings. They were both with the orchestra for something like 40 years, and probably still are. Both absolute masters of their field, very accomplished, well known, etc. They HATED each other. Never spoke a word to each other outside of what they had to get across to make sure that they were exactly in harmony, matching styles, dynamics, etc. But they had great respect for the other's craft, and what they could do with their instrument, and knew it was in the best interest of the orchestra as a whole that their performance was as harmonious as possible. I started thinking of that story a lot more after I became an engineer than when I was a musician. Best, Drew Northwestern Formula Racing Head Engineer, Frame/Suspension ----------------------------------------------------------------------------- "The Devil isn't in the details, it's the details that make the design." It has been proposed that we name the car after my girlfriend, so that I can spend all my time with her. [http://www.northwesternformularacing.com/]Northwestern Formula Racing[/URL] |
Lots of Good information compiled here!! we are on are way to translating this information for the Korean market and obtaining sponsors for the equipment. If your university offers you a shop (place to work out of) and tools...Be thankful!!!!! btw anyone know of any companies that regularly sponsor FSAE for tools? or of any companies that would be interested in sponsoring tools?
Team Leader, Aaron Park KAIST University fsae.kaist.ac.kr |
I know in the past we've gotten praise from the judges on our "team spirit." Part of that is because we have a small team and that's easier to manage.
But we try to have a little fun together. In 2007, about the time we started having some serious shouting matches about various decisions, we started playing a little game called soccer four-square. I think that game does wonders for morale - even if it's terrible for productivity, because it lets the team members feel like their taking a bit of aggression out on others in a constructive way. And we also have a pretty easy-going group of people. Between things like that and having fun with the car (frilly pushbars, dummy dash knobs that go to 11, etc.) we let everyone vent a little bit with some pure communal creativity, without all that engineering crap. University of Oklahoma Sooner Racing Team Cooling Lead '09 Engine Lead '08 sae.ou.edu "Remember, if you can't fix it with a hammer, you've got an electrical problem" |
Drew Price wrote
A big reason why they don't make every mic a tenth's reading mic is the difference between precision and accuracy. First, if your part is over 2" or 3", and you want to spec to less than a thou, you need to also spec temperatures. Second, the measurement technique used with a mic is really only accurate down to about a thou - user error means that you and your buddy will measure the same thing with the same tool and get different results at granularity of much less than a thou. Also - you can accurately interpolate to a quarter or half thou on any micrometer, simply by judging between the lines. Now, comparative measurements done by one person with one tool can get pretty accurate. That's what gauge blocks are good for, dial bore gauges, etc. Snap gauges are pretty inaccurate if you're worried about tenth's... Brian |
True, but if your parts are larger than the range of the 2"-3" mic, are you really needing to hold a tolerance of under a thou? Most times not, sometimes maybe, and at that point you should be getting out the jo blocks and zeroing the thing before you do the final measurements anyways. I just never understood why a mic, which is geared towards the precision side of the Accuracy v. Precision scale, should show the same precision as the caliper, which is somewhere in the middle I suppose. Good calipers should be within 0.001" for anything appreciably large enough, it's only when I need under a thou that I go for the mic anyways, not worth the hassle if +/-0.001" will do.
We don't make our own wheel centers or flywheels, about the only things I can think of that teams would make where you do need the large size accuracy. Some of the brake rotor mounting flanges / offset plates we made last year maybe, but that's about it. Repeatability really is the bane of existence though, you got that one. Best, Drew Northwestern Formula Racing Head Engineer, Frame/Suspension ----------------------------------------------------------------------------- "The Devil isn't in the details, it's the details that make the design." It has been proposed that we name the car after my girlfriend, so that I can spend all my time with her. [http://www.northwesternformularacing.com/]Northwestern Formula Racing[/URL] |
We don't make our own wheel centers or flywheels, about the only things I can think of that teams would make where you do need the large size accuracy (for balance, as we don't have a balancer). Some of the brake rotor mounting flanges / offset plates we made last year maybe, but that's about it. Repeatability really is the bane of existence though, you got that one. Best, Drew Northwestern Formula Racing Head Engineer, Frame/Suspension ----------------------------------------------------------------------------- "The Devil isn't in the details, it's the details that make the design." It has been proposed that we name the car after my girlfriend, so that I can spend all my time with her. [http://www.northwesternformularacing.com/]Northwestern Formula Racing[/URL] |
