| Member |
Bob, That last sentence will scare a lot of teams. I guess we are all secretly hoping that GFR fall into the group of successful teams that fall due to not wanting to change their winning formula. Kev | |||
| Member |
Going way back to Kev's comments, I agree on nearly all points you made. The rest of the field does make a big difference to the spread and should be accounted for. The margins do narrow with a very fast 4 taking down accel. I still think there should be a reasonable margin in the fuel used between a 4 and a single produced by the same team, for us it was a little over 1L. I think it would probably be similar for most teams, even across different levels of engine development expertise. I completely agree that teams can still score very highly (and even win on occasion) with a car that is very far from the theoretical optimum, but I am not considering those factors in this discussion. Just trying to imagine what the highest scoring car that you could realistically build for this competition would look like, without concerning ourselves with boring limitations, timelines and resources. Z, I have to agree with some points and disagree on others. While "high downforce does not have to imply high drag" all too often it works out that way due to the other restrictions we face in the design of these vehicles (package space, integration, CG height issues, weight etc). For example, rather than use a multielement wing (CL =4) I could run a single element wing (CL =1) but I would have to make it maybe twice the plan area and double the span. It just not possible within the rules, and besides it would weigh more and increase our cg height (if it were a high mount rear wing). When designing aero for these cars you quickly realise that you are designing less for "efficiency" and more for "effectiveness". A wing that is twice as efficient is frequently half as effective. You are correct about Carroll Smith saying "Aero cars will dominate", about 10 years ago. He was talking about our 2002 car (the first with full diffuser and unsprung wings) when he said it. I recorded it and put it in this video(about 2mins in) if anyone is interested in watching it: (excuse the drum and bass, or rock out... your choice) http://www.youtube.com/watch?v=dkuwIW_Wp3U I'm pretty sure I met you (Z) briefly you at this comp as well, I had a Blue mohawk at the time (like the entire rest of the team!) Speaking of high mounted wings, they are a necessary evil. I like the aero ideas you put forward with your twin beam wing design, particularly the front but I seriously doubt the rear is going to make much DF as it is in the wake of the front. If we get a chance we will run some quick sims on it to check. The flow coming off the front wing ends up at driver head height, leaving only dead air near the rear wheels. This is evident in the problems aero teams have getting radiators to work down there. It also means the diffuser doesn't work as good at the back. If you cant bring clean air in from the sides, you have to go high (as you cant go wider). The more aggressive your front wing the higher you have to go which means the more front you need etc etc. I predict biplane front wings will make an appearance in the future to try and remedy this imbalance. At first glance it may appear that we are simply mimicking real race cars, but in fact we don't have much choice (or none that I can see). We have thought about Wheel pods in the past, but don't run them because the front wing covers the front wheels and the radiators cover the rear wheels. Would you believe we even thought about the tailfin/steerable sails that you proposed, way back in 2002. We reasoned that any sail side force created would incur an equivalent drag to that of a traditional down forcing wing. The downforcing wing however has the advantage of the CoF multiplier, hence is more efficient way to "spend" that drag. Common sense kicked in when we started thinking about optimising it through dynamic roll angle adjustment (as discussed here) and we decided to focus on more pressing problems of getting a car built and tested! Drag Reduction Systems may in fact be a wank. On the other hand they may be a very easy and reliable points gain, for an investment of $200 and about a weeks work. The devil with this one is in the details, which is why we have built and tunnel tested a system and are now experimenting with it on track. In our first test we found it was super easy for the driver to actuate it via a button on the wheel, so we will not bother with any computer logic control like Sooner used. The car pulls really hard in a straight line again (for the first time) which is great. If we get a track with a lot of straight lines (or softly curving ones) then I cant see how it wont be a benefit. Consider that with full wing we are hitting terminal speed in SLALOMS of around 16m spacing. Unlike F1 we can actuate as much of our wing as we like (front included) and for as long as we like. Granted our straights are not as long, but I think we would use it for a larger proportion of the lap than they are allowed. Hardly mindless mimicking "just because people don't post all of their calculations, doesn't me they didn't do them" I'm sure Maryland have been through all this and ten times more, but don't necessarily want to talk about it as much as some. I agree with Bob's comments on the problems associated with under trays. We are trying to validate (or otherwise) ours at the moment and it is a nightmare, even with 64 channels of high speed pressure tapping. If we manage to make something of the data it might appear at the SAE congress in 2013. Also I think Bob's comment is spot on: "Under the new rules, again IMHO, aero is going to be necessary (but not sufficient) to win a major competition." The thought of GFR coming back with bigger wings is going to keep me awake at night... Perhaps non-aero teams should start sharpening their knives? :P Scott Regards, Scott Wordley Scoring in every event for the last 12 comps running! http://www.monashmotorsport.com/ | |||
| Member |
Scott, Great points as usual. I think the question shouldn't be 1 vs 4 cylinders, rather it should be light vs. heavy engines. The highest performance FSAE engine is still to be made. Resource allocation issues may mean it never gets made. We still saw in Australia that UWA outscored Monash on dynamic events. Both teams had cars that had been running for quite a while, both with great driver teams, which if we counted all competing drivers I would say Monash's was better. I still agree that the Monash concept is probably theoretically better given the points sims we have run. The fuel use difference is another interesting question. I would accept about 1L between a single and a 4 with both on full tilt. However the 4 teams are moving towards conserving fuel in endurance, while the singles have more need to wring the power out. I would say given different comp strategies the difference would be smaller. I think we saw some of this in Australia, and some with what Stuttgart has been doing in endurance. We have had a brief look at the strategy behind different concepts and there does appear to be two main ways to gain a slight advantage: 1. Gain the points that the main competition ignores. Having a different car to the bulk of the main players in a given comp means you have a window to uncontested points. 2. Lead early. This both puts pressure on your competitors (forcing errors), as well as setting you up for any change in conditions. At the moment this still favours the lightweight high aero car, which has the potential to lead early (being one of the higher performance concepts) and as well being the odd one out. Still doesn't give an explanation for the UWA dynamic win in Australia. Kev | |||
| Member |
Kev, Hmmmmm...., err...., maybe.... it's because they've got an..... aero undertray??? Oh, yes...., and also a.... soft twist-mode??? (Yes, I know, that doesn't prove anything... ~~~o0o~~~ And as Mike says, UWA are certainly not going to promote those ideas here, in public! (Maybe I'd best shut up now. Sorry Pete.) ~~~o0o~~~ Scott, my mohawk is a lot greyer now. Z | |||
| Member |
Z, first of all I apologize because I didn't found the time to answer when you post your concept (ok, I also red several posts of this topic too fast! sorry, too busy at work). I found it interesting but I not sure that aero package can work so well (there is a bluff body inside the wing and a hole between lower and upper surface). That's only a "chat", it need at least a CFD sim to find out what happen. About you "aero undertray" don't forget that undertray and rear wing work together. You can improve your undertray performance with a rear wing. I remember Sophia ran with an undertray and a rear wing. The sail car is less foul as one can imagine. They are good if you don't need to steer so much. I'm not sure it would be easy to manage it on a FSAE track. Is Russell Coutts eligible to drive a Formula SAE? Lorenzo Pessa (an angry) volunteer at FSAE-I 2012 D-Team UniPisa (alumni group) E-Team Squadra Corse - Università di Pisa FSG & FSAE-I 2009-2010 | |||
While Stuttgart has made significant progress, TU Munich is the team that has really trimmed their fuel usage this last year. 3,4 liters at FSG, and 3,2 at Michigan. But the single teams certainly aren't ignoring fuel. ETS won design at California last year because of their engine development. They won endurance whilst using 2,3 liters of fuel. That's still a liter and about a 30-40 point advantage over the most fuel efficient fast 4s. I see Munich and Stuttgart have entered FSUK as E85 cars. That will give them another 10-15% in fuel. Bob Paasch Faculty Advisor Global Formula Racing team/Oregon State SAE | |||
| Member |
Kev, Consider that UWA actually used less fuel than us in Aus. I would also mention that the Aus track was particularly aero unfriendly this year. We are also a lot heavier than what is theoretically achieveable for an aero single, as it was our first time out with this package and we designed and built in 6 months. So on this basis I wouldn't necessarily consider Monash versus UWA as a fair comparison of these two "concepts". I think there is much more room for improvement on our end, while I think the current UWA/Munich/Stutgartt cars are about as close to as good as a 4 cylinder non-aero cars can get. I am pretty sure some of the good engine tech teams could comfortably go under 2L fuel used, if they switched to a single, possibly whilst running wings. We are planning on going E85 as well, but didn't have time to get it set up for Europe. It does appear to provide a reliable increase in Fuel Economy. Regarding the highest performance engine being yet to made made... if anyone thinks they can do better than the major bike manufacturers then please be my guest! Consider talking to teams like WWU, Melbourne Uni, Aachen(?) and Auckland who have gone down this route and see what their advice is. Look up their historical scores as well. Once you finish your bespoke engine please calculate the differential in points scored compared to what you achieved running an off the shelf engine, and then divide that by the amount of time, money and resources you have invested. Interested in what that "number" would look like and if it would be positive. Historically speaking, I think it is more commonly negative. Regards, Scott Wordley Scoring in every event for the last 12 comps running! http://www.monashmotorsport.com/ | |||
| Member |
Scott, Please don't mistake my queries for an attack on the concept. I agree that UWA's car is about as good as that current concept currently is and Monash are only at the beginning (especially with a new engine). I was genuinely surprised that UWA won the dynamics. Unless I am mistaken the last time the Monash concept (only with less aero and a four) went up against the UWA concept where both competed(2009), Monash was the comfortable dynamic winner. Clearly on average in 2011 Monash had the better driving squad based on lap times. We could probably say that UWA's engine was better developed, as was their mechanical grip. But on the other hand very few teams develop Aero as well as Monash. Did we see mechanical grip and engine development trump better aero? With further development I expect Monash would have a much better dynamic scoring car (which does worry me). But I also expected them to have the edge in 2011. The track at Australia was ridiculous. They had a problem with getting barriers in time so designed the most twisty and cone filled course that has been run at Werribee. No team was more disappointed at this than ECU. On the other hand it does make a case for non-aero teams to be a bit happier with their design choices. Aero teams do want reasonable course design to perform their best. Monash also lost the dynamics on the back of hitting far too many cones. While the cone hitting issue of wings is not as bad as some would believe, it still exists. I agree with the resource allocation arguments related to custom engines. But it doesn't change the fact that engine development is more valuable now. Aero has made weight much more important, and the rules have made economy more important. I would expect to see new engines at least in the form of heavily modified bike engines; maybe new cases with original head and internals. The main problem with existing bike engines is packaging, leading to increased weight. Engines are still worth less than mechanical grip and aero in terms of performance, but the changes to the rules have made it more inviting. If a team can find and manage the resources effectively they have a chance to pull out an advantage. I would have easily dismissed a custom engine previously, but now I wonder if a longer term design program might be worth it to teams, especially those that already have good engine development backgrounds. I don't think the small number of custom engines we have seen so far is anything but the early stages of this line of development. Regardless I think we are in for interesting developments in the next few years, as it is pretty clear the goalpost has changed. Kev | |||
| Member |
First of all the rules clearly say that the car has to be "open-wheeled". Of course there is a grey area were this starts and ends. But what I'm really interested in is how you want to not accept if scrutineers don't allow it. If they insist, it's against the rules you remove it - or you don't compete in the dynamics. I wouldn't accept closed tear-shaped and steered covers over the wheels as they are clearly against the open-wheeled rule. Not just against the spirit or intend if a rule. Rennteam Uni Stuttgart 2008: Seat and Bodywork 2009: Team captain GreenTeam Uni Stuttgart 2010: Seat and Bodywork / Lamination whore Formula Student Austria 2012: Operative Team | |||
| Member |
The Dallara DW12 is still an 'open wheeled' car. It competes in 'open wheel' racing... Could maybe even argue (and prove) that they served to help mitigate tire-to-tire contact and absorb energy in side and rear impacts. Scott Brenaman Portland State Alumni - 2010, 2011 - Technical Director Desire is the key to motivation, but it's determination and commitment to an unrelenting pursuit of your goal - a commitment to excellence - that will enable you to attain the success you seek. - Mario Andretti | |||
| Member |
I'm still waiting to see a descent clarification on the wheel covering thing. I think we need one, and after Aus '11, I'm surprised nothing has been done. Yes I know there is already a clarification, but it makes all the traditional aero cars illegal, and clearly they are being allowed to run, so it would seem there is plenty of "interpretation" even in the "clarification". (it says you must be able to see the tyres in plan view). This can be easily circumvented anyway, it would just cause another hassle at comp, but still, we might just show up with fully covered wheels that meet ALL the rules!!! AND then complain that we can't see Monash's, ECU's etc rear tyres in plan view! The Aus comp fuel economy points call for covered wheels IMO, (if going with a low drag 4 cyl) and if the organizers don't want that, then make a rule that stops it. SCCA, FIA, etc have managed to. Pete | |||
| Member |
Lorenzo, Yes, as you say, an "undertray and rear wing work together". And they work especially well if they are close-coupled. That is, if the "wing" is just above and behind the rear edge of the undertray. But I would now call that "wing" the "undertray flap". All FSAE aero students should note that an undertray with DIFFUSER ONLY is just the first step to large downforce. In aeronautics a single element aerofoil will only generate Cl up to about ~1.5 before stalling. For much higher Cls the wing needs slots, or flaps. See Handley-Page experiments, early 1900s, multi-slotted wing (~8 elements?) with Cl=~4 (more slots gave more Cl). So add one or two+ flaps to the back of your undertray, and watch downforce+++! ~~~o0o~~~ Bemo, You say, "First of all the rules clearly say that the car has to be "open-wheeled". Of course there is a grey area were this starts and ends. But what I'm really interested in is how you want to not accept if scrutineers don't allow it." Well the sad fact of life that you will soon have to learn, even as engineers, is that there will be times in your careers when you have to (to use Monty Burns' words) "unleash the hounds", ie. call in the laywers. (Eg. Microsoft didn't get to where they are today by writing better software. They just used their lawyers more aggressively. I don't like it. But if you have spent too long arguing with the scrutineers that "there is nothing in the rules against it", and they still want to ban you, then I suggest passing them your mobile phone with your school's legal representative on the other end. Your "rottweiler" lets them know that "the entire future income prospects of all our team members (ie. mega-million$$$) depends on our team being allowed to compete, fairly and to the same rules as all the other teams, in this competition. Blah, blah, .... we'll sue the pants off you,... blah, blah, blah..." Like I say, I don't like that sort of thing. But frankly, the teams' efforts are now very professional, whereas the organisation of FSAE seems to remain very amateurish. They need a kick up the bum, to help lift their game. Put simply, to the organizers of FSAE, either let the "interesting" cars run, or else write the rules properly! And, as Scott B notes above, those Indy cars are "podded" because it is better for safety and fuel economy! ~~~o0o~~~ Regarding "aero sideforce", this has been in use for a long time on Speedway cars that carry the huge central "roof-wings", with equally huge side plates. Since these cars spend a lot of time at about a 45 degree slip-angle, their aero sideforce is sometimes seen to roll the cars INTO the corners. Or, perhaps a better description is that the air grabs hold of the high mounted wing, and the bottom of the car swings outward. Z | |||
There is a lot of misconception about those rears pods, originating from speculation I believe. The number 1 reason those rear pods are on the new Indy cars, is to stop front and rear wheels interlocking if cars bang together. Hence making them safer. As a side effect/consequence there is an aero improvement (good engineering design in the shape), but ultimately they were on the car regardless. Cheers ______________________________________________ Nothing is impossible. Improbable yes. But not impossible. Swinburne University of Technology www.teamswinburne.com/petrol BoffinMotorsport@gmail.com 2011 Electric car detester & Dyno/Engine guru - TS_10J - Japan competition 2010 Dyno/Engine guru 2009 Dyno/Engine guru 2008 Random gunt | |||
| Member |
What is the idea for requiring the cars to be open wheeled anyway? It would be very interesting to see if we could arrive at a rules set that saw exciting competition between a lighter Open-Wheeled car and a heavier Le-Mans or Daytona Protype style car. Scott Brenaman Portland State Alumni - 2010, 2011 - Technical Director Desire is the key to motivation, but it's determination and commitment to an unrelenting pursuit of your goal - a commitment to excellence - that will enable you to attain the success you seek. - Mario Andretti | |||
| Member |
Z, as I understand you are not a student anymore but are also not involved as a volunteer or otherwise in any FSAE organization comittee. In that case I would expect you to change that instead of complaining. Regarding the lawyer stuff: If the respective scrutineer has any balls, he would not mind. FSAE Rule A3.10 gives him the power to do whatever he thinks is appropriate. Fantomas Scores under pressure | |||
| Member |
And there is a point in life where you learn that one can not always get one´s way with brute force. The Scrutineers have many ways to make your life VERY uncomfortable, like inspections of your engines displacement which in a lot of cars means removing the engine from the car e.g. Of course they usually wont let you do this, but thats only because its not their intent to cause you trouble. However trying to really piss of a scrutineer, especially with something as ridiculous as a lawyer, might not be a very clever idea in the end. And i dont think any scrutineer will have anything of this lawyer talk in the first place. | |||
| Member |
And you shouldn't forget that there is the "intent of the rule". The rules set gives the organisers the power to interpret the rules. So even if you would really want to send in your lawyers I doubt you would be succesful with that. Especially because of the point RenM already threw in. If I were your scrutineer and you would argument like that, you definitely wouldn't have a nice time. If you really want to, you will always find issues on any FSAE car. There is still the very old rule. If you enter some "grey area" of the rules, ask the rules commitee about it. If you do so, you know wether it will be accepted or not. I agree with you that this particular rule needs additional clearification, as the best thing is, if there is nothing to argue about. I personally wouldn't have a problem with it, if the rule would just be erased as I don't see any safety issues and it would increase the freedom in the designing process. Rennteam Uni Stuttgart 2008: Seat and Bodywork 2009: Team captain GreenTeam Uni Stuttgart 2010: Seat and Bodywork / Lamination whore Formula Student Austria 2012: Operative Team | |||
| Member |
"Regarding "aero sideforce", this has been in use for a long time on Speedway cars that carry the huge central "roof-wings", with equally huge side plates. Since these cars spend a lot of time at about a 45 degree slip-angle, their aero sideforce is sometimes seen to roll the cars INTO the corners. Or, perhaps a better description is that the air grabs hold of the high mounted wing, and the bottom of the car swings outward." Z[/QUOTE] Seeing a World of Outlaw race made me wonder if these rednecks actually understood how they make those cars produce the herculean feats that they achieve or if it was just sheer balls of trying things out. Its something else to see the inside rear tire wrinkle up like a drag tire when the car is pitched sideways at a 100mph. Super Modified used to have the coolest design solutions to the problems at hand and like always were banned for being too smart.... http://www.jakessite.com/07/re/index.htm http://web.a-znet.com/~dave1w/shampine.htm http://www.jimmyjeep.com/4x4.html http://www.jakessite.com/07/re/crmfillipchet.htm http://sitepalace.com/donmichael/reece/reece.html sbrenaman, It would be nice to have full freedom and let the concepts prove themselves out of open wheel,closed wheel and hybrid wheel such as this... http://www.race-cars.com/carso.../m832c1/m832c1pp.htm Can Am in its reduced cost 2 liter format ended up being wheel hybrid wheel Formula 2 cars. -I might be stupid but I got retard strength -"I hate Rob Woods" tee shirts are now for sale -I know the strippers real name. -Because eggs is eggs | |||
| Member |
Funny thing what came up on Speedhunters... http://speedhunters.com/archiv...ngs-and-prayers.aspx --- Harry Bikas U.o.P. Racing Team - Chassis/Composites UoP Racing website UoP Racing on Facebook UoP Racing on Twitter UoP Racing videos | |||
| Member |
RJW - I am hoping for something more like this, but open cockpit Scott Brenaman Portland State Alumni - 2010, 2011 - Technical Director Desire is the key to motivation, but it's determination and commitment to an unrelenting pursuit of your goal - a commitment to excellence - that will enable you to attain the success you seek. - Mario Andretti | |||
